[mapserver-users] Re: Fwd: Best and simplest solution for setting
up a raster map server
Ibrahim Saricicek
ibrahimsaricicek at gmail.com
Mon Apr 12 07:02:11 EDT 2010
Have you geo-referenced (registered) your rasters.
If so try mapserver+openlayers.
This explains how you add your raster layers.
http://mapserver.org/input/raster.html
And this is an example of mapserver and openlayers.
http://openlayers.org/dev/examples/mapserver.html
Your map file will be like this..
MAP
NAME MAPFILE
STATUS ON
SIZE 800 600
SYMBOLSET ../etc/symbols.sym
FONTSET ../etc/fonts.txt
EXTENT -20037508 -20037508 20037508 20037508.34
UNITS METERS
SHAPEPATH "../data"
IMAGECOLOR 255 255 255
DEBUG 4
MAXSIZE 3000
OUTPUTFORMAT
NAME PNG
DRIVER "GD/PNG"
MIMETYPE "image/PNG"
IMAGEMODE RGB
EXTENSION "PNG"
TRANSPARENT ON
FORMATOPTION "INTERLACE=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
FORMATOPTION "QUANTIZE_FORCE=ON"
END
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_title" "World"
"wms_onlineresource"
"http://127.0.0.1/cgi-bin/world.exe?MAP=/ms4w/apps/gmap/htdocs/world_900913.map"
"wms_srs" "EPSG:4326 EPSG:900913" #always capital letters
'wms_feature_info_mime_type' 'text/html'
'wms_encoding' 'UTF-8'
END
END
PROJECTION
"init=epsg:900913"
END
LAYER
NAME 'Raster'
DATA "C:\myraster.tif"
TYPE RASTER
PROJECTION
"init=epsg:4326"
END
STATUS ON
END #Layer
END # Map File
View this message in context: http://n2.nabble.com/Fwd-Best-and-simplest-solution-for-setting-up-a-raster-map-server-tp4886892p4889407.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
