[mapserver-users] can not compile arcsde 9.3 with mapserver 5.4
Jachym Cepicky
jachym.cepicky at gmail.com
Wed Apr 14 11:36:55 EDT 2010
no idea :-( there are
documentation_sdk hpia_64 ibm install_sdk.htm solaris windows
hp hp_64 ibm_64 linux solaris_64
directories on the CD (so nothing like linux_64 or windows_64)
the system is
Linux mapgis 2.6.18-164.15.1.el5 #1 SMP Wed Mar 17 11:30:06 EDT 2010
x86_64 x86_64 x86_64 GNU/Linux
removing the duble slash did not help :/
how could I found out, which architecture are the given libs for?
thanks
jachym
2010/4/14 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>:
> Perhaps the double / is problematic? Try:
> --with-sde="/opt/arcsde/sdeexe93"
> Also, does the library architecture match your system?
> Steve
> ________________________________________
> From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jachym Cepicky [jachym.cepicky at gmail.com]
> Sent: Wednesday, April 14, 2010 3:55 AM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] can not compile arcsde 9.3 with mapserver 5.4
> Hi,
> I have the SDK, I installed it using "install -load" script
> when I try to compile mapserver 5.4.2, configure works,
> ./configure [...]
> --with-sde="/opt/arcsde/sdeexe93/" \
> --with-sde-version=93 \
> but whild compilating, I get
> usr/lib64 -lagg -laggfontfreetype -ltiff -ljpeg -lfreetype -lpng -lz
> -lXpm -lX11 -lproj -ljpeg -lpng -L/opt/arcsde/sdeexe93//lib -lsde
> -lpe -lsg -lpthread -ldl -lgdal -L/usr/lib64 -lpq -rdynamic
> -L/usr/lib64/mysql -lmysqlclient -lz -lcrypt -lnsl -lm -L/usr/lib64
> -lssl -lcrypto -lmysqlclient -L/usr/kerberos/lib64 -lcurl -ldl
> -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lidn -lssl -lcrypto -lz
> -L/usr/lib64 -lgeos_c -lpthread -lc -lz -lxml2 -lz -lm -lfribidi
> -lm -lstdc++ -o shp2img
> /usr/bin/ld: skipping incompatible /opt/arcsde/sdeexe93//lib/libsde.so
> when searching for -lsde
> /usr/bin/ld: skipping incompatible /opt/arcsde/sdeexe93//lib/libsde.a
> /usr/bin/ld: cannot find -lsde
> collect2: ld returned 1 exit status
> any hint?
> thanks
> jachym
> Dne 12. dubna 2010 8:00 Jachym Cepicky <jachym.cepicky at gmail.com> napsal(a):
>> Hi,
>> slowly, I'm approaching. Our customer had to write to out local service
>> provider of ESRI and they had to write to ESRI and request for the
>> header files (I can not find the page, where it was written, but the
>> header files should just arrive from U.S. here).
>> So, now I "should" be able to compile
>> Thanks
>> Jachym
>> Lime, Steve D (DNR) píše v St 07. 04. 2010 v 16:40 -0500:
>>> Don't know if success was had or not. The standard 9.3 disks I had access to did not have the headers available. Must need some super secret handshake to get them. Anyway, I just copied the 9.2 headers into the same spot in the 9.3 directories and it works just fine. Don't know that I'd recommend that approach in lieu of learning the super secret handshake but it worked here in a pinch...
>>> Steve
>>> -----Original Message-----
>>> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Huey Brantley
>>> Sent: Thursday, March 18, 2010 10:44 PM
>>> To: Jachym Cepicky
>>> Cc: mapserver-users at lists.osgeo.org
>>> Compile it against the SDE SDK, not where you have SDE installed.
>>> My configure:
>>> ./configure \
>>> --with-php=/usr/local \
>>> --with-proj=/usr/local \
>>> --with-gd=/usr/local \
>>> --with-jpeg=/usr/local \
>>> --with-png=/usr/local \
>>> --with-sde=/u01/arcgis93sdk/sdeexe93/ \
>>> --with-wfs \
>>> --with-ogr=/usr/local/bin/gdal-config \
>>> --with-gdal=/usr/local/bin/gdal-config \
>>> --with-freetype \
>>> --with-tiff \
>>> --with-agg \
>>> --with-curl \
>>> --enable-debug
>>> Jachym Cepicky wrote:
>>> > Hi,
>>> > I'm not able to get arcsde 9.3.0 compiled with mapserver (5.4), on Linux
>>> > I use
>>> > ./configure --with-sde=/opt/arcsde/9.3.0/sdeexe93/ --with-sde-version=''
>>> > the arcsde installation directory containes (among others) file
>>> > libsde.so
>>> > nut not "*.a" file or "*.h" files
>>> > however, I get
>>> > configure: error: "Could not find sdetype.h or libsde.a/libsde.so in
>>> > /opt/arcsde/9.3.0/sdeexe93/."
>>> > Any hint?
>>> > Thanks
>>> > Jachym
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Jachym Cepicky
>> e-mail: jachym.cepicky gmail com
>> URL: http://les-ejk.cz
>> PGP Public key: http://les-ejk.cz/pgp/JachymCepicky.pgp
> Jachym Cepicky
> GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
Jachym Cepicky
