[mapserver-users] converting line object to series of points
Andy Colson
andy at squeakycode.net
Thu Apr 15 13:29:12 EDT 2010
On 4/15/2010 12:07 PM, Mark Brooks wrote:
> Thanks for your insights and help.
> The lines I'm working with will have multiple points. They are hurricane
> tracks. The tracks are made of points, about 3-12 hours apart.
> Therefore, sometimes the points are close and other times very far away
> from each other. I can easily connect the track points to create a line.
> But I need the points in between each observation so that I can
> determine what county landfall occurs. The y=mx+b method will work, but
> I was hoping there may be an easier to do it. Or perhaps I'm making the
> problem too complicated to begin with??
> Mark
Well thats an interesting problem. I'm not sure how to do it with lines
or points. If you had a line, you could tell if it intersects a polygon
(a county), but then it might intersect many polygons... maybe?
On the other hand if you plot points along the line, checking each time
if you intersect a polygon (a county), would you plug values into x or
y? Increasing or decreasing? If your points are too far apart you
might miss a polygon, but if they are too close together you'll waste a
lot of time processing.
Hum... what if you use a line, find all polygons that intersect that
line, then find the polygon nearest the start point?
On a side note.. aren't hurricane's really wide? Wouldn't several
counties get hit at the same time?
-Andy
