[mapserver-users] mapserver as a tiling client for an untiled WMS
DeDuikertjes
DeDuikertjes at xs4all.nl
Sun Apr 18 15:04:03 EDT 2010
Michael,
Thank you.
Do I understand correctly that this GDAL WMS Minidriver with this xml
file for a given map area (bounding box) will do a series of "normal"
WMS requests (as opposed to "tiled" WMS requests) to the server to
obtain a set of tiles which will be stitched together and incorporated
in the map?
MArco
Smith, Michael ERDC-CRREL-NH schreef:
> Marco,
> To use the GDAL WMS Minidriver, create an XML file like below and then
> reference that xml file in your MapServer layer. For more info about the
> format of the WMS xml, see here http://www.gdal.org/frmt_wms.html
> Example xml
> <GDAL_WMS>
> <Service name="WMS">
> <Version>1.1.1</Version>
> <ServerUrl>http://hazards.fema.gov/wmsconnector/wmsconnector/com.esri.wms.E
> srimap/NFHL?transparent=true&</ServerUrl>
> <SRS>EPSG:4326</SRS>
> <Layers>Flood_Hazard_Zones_General</Layers>
> <Styles>default</Styles>
> <ImageFormat>image/gif</ImageFormat>
> </Service>
> <DataWindow>
> <UpperLeftX>-180.0</UpperLeftX>
> <UpperLeftY>90.0</UpperLeftY>
> <LowerRightX>180.0</LowerRightX>
> <LowerRightY>-90.0</LowerRightY>
> <TileLevel>19</TileLevel>
> <TileCountX>2</TileCountX>
> <TileCountY>1</TileCountY>
> </DataWindow>
> <Projection>EPSG:4326</Projection>
> <BlockSizeX>1024</BlockSizeX>
> <BlockSizeY>1024</BlockSizeY>
> <BandsCount>3</BandsCount>
> <Cache>
> <Path>/htdocs/orm/gdalwmscache</Path>
> <Depth>2</Depth>
> <Extension>.gif</Extension>
> </Cache>
> <AdviseRead>true</AdviseRead>
> <VerifyAdviseRead>true</VerifyAdviseRead>
> </GDAL_WMS>
> Mapfile section
> LAYER
> NAME femaq3
> DATA "/data/fema/fema_gen_wms.xml"
> OFFSITE 255 255 255
> TYPE raster
> STATUS off
> PROJECTION
> "proj=latlong"
> "ellps=GRS80"
> END
> CLASS
> NAME "100 year floodplain"
> SYMBOL 0
> COLOR 255 0 0
> END
> CLASS
> NAME "500 year floodplain"
> SYMBOL 0
> COLOR 255 192 203
> END
> END
