[mapserver-users] Does Mapserver WCS 1.0.0 respect OFFSITE of
tileindex layer?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Apr 19 10:10:11 EDT 2010
Frank Warmerdam wrote:
> Jukka,
> Generally WCS generated geotiffs will not have a way to
> represent nodata
> in a way that a client application is likely to recognise
> them as nodata.
> By default pixels which are assigned no value from the source
> dataset are
> set to zero.
I am not sure if I could tell clearly what was my problem. I will try
again. I have layers like this:
LAYER
NAME "M138"
METADATA
"wcs_label" "M138"
"OWS_EXTENT" "86000 6636000 650000 7518000"
"WCS_RESOLUTION" "0.5 0.5"
"WCS_SIZE" "50000 50000"
"WCS_BANDCOUNT" "1"
END
STATUS ON
TILEINDEX "d:/dataM138"
TYPE RASTER
UNITS METERS
SIZEUNITS PIXELS
OFFSITE 0 0 0
TOLERANCE 3
TOLERANCEUNITS PIXELS
PROJECTION
"init=epsg:3067"
END
DUMP TRUE
END
Tiles combined by M138_WMS.shp overlap because they are reprojected.
When I use this layer through WMS, having OFFSITE 0 0 0 makes the black
nodata triagles transparent and warped images make a seamless mosaic.
Somehow I was awaiting that WCS behaves in a similar way, but it does
not. Black nodata triangles are burned into the output image and the
mosaic is useless. I can get my job done by hand editing WMS calls so
that the BBOX and WIDTH and HEIGHT give me the desired pixel size, but
it would be a bit more simple through WCS GetCoverage and ResX, ResY.
-Jukka-
