[mapserver-users] having trouble with label size
Daniel Morissette
dmorissette at mapgears.com
Thu Apr 22 09:03:09 EDT 2010
Worth Lutz wrote:
> I believe that what you are looking for is DEFRESOLUTION in the mapfile at
> the MAP level. From what I remember seeing on this list is that you set
> RESOLUTION 300
> DEFRESOLUTION 72
> And then increase the size of your map to get the large size at 300 dpi.
> I'm not sure when this was added but it is not in the documentation.
> Hopefully someone will add to this information.
This was added in MS 5.6. Unfortunately the doc is a bit behind, but you
can find all relevant info about the new RESOLUTION/DEFRESOLUTION
support in RFC-55:
http://mapserver.org/development/rfc/ms-rfc-55.html
Daniel
Daniel Morissette
http://www.mapgears.com/
