[mapserver-users] Re: Mapscript c# VS 2010 framework 4 and
memoryleaks - Found word(s) list error in the Text body [Keyword]
Tamas Szekeres
szekerest at gmail.com
Thu Apr 22 09:41:13 EDT 2010
2010/4/22 James Perrins <james.perrins at gmail.com>:
> Need to add:
> using System.Security;
> [assembly: SecurityRules(SecurityRuleSet.Level1)]
> I haven't yet found anything that says where you can do this once for
> an assembly - or whether you have to mark each class (probably doesn't
> hurt to mark each class) - all the examples are a bit trivial
James,
You could add this line in
AssemblyInfo.cs<http://trac.osgeo.org/mapserver/browser/trunk/mapserver/mapscript/csharp/config/AssemblyInfo.cs>which
won't be re-generated during the build process. However I'd be
curious to know whether this change breaks the existing builds with
VS2003/VS2005/VS2008. If yes, then this addition should be conditional to
VS2010 only.
> I've found some source in a slightly different location from your
suggestions:
> ~\mapserver-5-6\mapscript\
> csharp
Ah, it seems I was referring to the GDAL project, but it seems you've
already found it.
> As an aside (and why I've been caught with this) is that referencing
> the mapscript_csharp.dll in a CLR 4 app works in design mode
> apparently fine. Its only when you try and run the compiled exe (or
> as it turns out switch off "suppress jit optimization on module load
> (managed code only)"). At that point even trying to load a mapObj
> results in numerous memory errrors
It would be helpful to submit a new
ticket<http://trac.osgeo.org/mapserver/newticket>for this issue and
describe your experiences here.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100422/dab08e55/attachment-0001.html
