[mapserver-users] Disregard ECW header for TFW in TILEINDEX ?
Frank Warmerdam
warmerdam at pobox.com
Mon Apr 26 10:41:00 EDT 2010
Lars I. Nielsen (GisPro) wrote:
> Hi,
> I'm trying to set up Mapserver as a WMS server, serving multiple
> seamless coverages consisting of ECW raster tiles.
> My problem is, that the ECW files have been delivered with faulty header
> information, and there's too many to fix manually, and the error cannot
> easily be remedied programmatically.
> However, I have generated TFW files for each tile that are correct, but
> how do I force Mapserver to use the TFW files and disregard the faulty
> ECW header ?
Lars,
As it happens this is not a unique situation and MapServer itself has some
logic to address it. If you add:
PROCESSING "EXTENT_PRIORITY=WORLD"
to your layer definition, then world files will be searched for in preference
to using the georeferencing returned by GDAL. I'm not sure exactly when this
was incorporated but I imagine it is in 5.4 and later. Also the file extension
should likely be either .eww or .wld, not .tfw for ecw files.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
