[mapserver-users] Can map server do this?
Jackey Cheung
cheung.jackey at gmail.com
Mon Apr 26 22:49:09 EDT 2010
Seems to be a good approach, though I haven't thought about this before. I
think I'll try look further into this.
Thanks for the hint :D
On Mon, Apr 26, 2010 at 10:51 PM, Lime, Steve D (DNR) <
Steve.Lime at state.mn.us> wrote:
> I can't tell from the example but it doesn't look like the map itself is
> oblique rather that the buildings are drawn in 2.5D.
> If so, this probably can be reduced to a data pre-processing exercise. I
> created a small test case (see attached) where a the pieces of a cube are
> drawn by MapServer. It was quick and dirty but it shows MapServer can
> possibly render like the example you referenced. Key is producing the
> cube (sides, top, and bottom) data. I would expect that could be done ahead
> of time via a script where you offset the footprint in the y direction
> by a height value and then compute the sides- each as a separate shape. I
> suppose it would be possible to create a plugin layer for this type of
> data (footprint + height) but easiest route is probably data
> pre-processing....
> Something to try anyway.
> Steve
> ___________________________________
> From: mapserver-users-bounces at lists.osgeo.org [
> mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jackey Cheung [
> cheung.jackey at gmail.com]
> Sent: Monday, April 26, 2010 2:53 AM
> To: Lars Lingner
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Can map server do this?
> Your effect is shadow like effects, not the "cube" like effect.
> On Mon, Apr 26, 2010 at 3:38 PM, Lars Lingner <ml at lingner.eu<mailto:
> ml at lingner.eu>> wrote:
> Jackey Cheung schrieb:
> > Just found a web site today. The map looks pretty like Google map, except
> > that it's not on Google. Can map server do this? Or anyone has any idea
> > which application can render this kind of image?
> I got a similar result using opacity and offset with MapServer. See
> image http://www.lingner.eu/mydownloads/pics/icc_building.png
> Lars
> mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100427/d22601d5/attachment-0001.html
