[mapserver-users] Re: WMS and tiles cutting off
Adam Eskreis
aeskreis at gmail.com
Thu Apr 29 14:24:08 EDT 2010
I have thought about using tilecache with metatiling, however there is a
caveat about this map that i forgot to mention in my main post, and it has
to do with that "categories" parameter. Basically, each point/symbol on the
map has an associated category in the database backend. I am using
mapserver/WMS parameters to change the categories which are called. Each
time the user selects a category, only the points in that category are
shown. My query in the mapfile looks something like thi:
SELECT point_geom,gid,symbol,angle FROM mapdata WHERE category
IN(%CATEGORIES%)";
And each time the user changes the categories, I use openlayers to merge new
parameters, and input the new category values that should be used. Is
tilecache still useable if I have a system like this set up?
Thanks,
-Adam
On Thu, Apr 29, 2010 at 6:14 AM, kaipi <mapcollect at gmx.net> wrote:
> Hi,
> you can use http://tilecache.org/ Tilecache with the option metatiling
> enabled. With metatiling enabled Tilecache will fetch larger tiles (eg.
> 4096x4096) from Mapserver and will cut them into smaller tiles (eg.
> 256x256). It will also increase performance because Mapserver does not need
> to render tiles when they are already in cache.
> kaipi
> http://osgeo-org.1803224.n2.nabble.com/WMS-and-tiles-cutting-off-tp4978418p4979280.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100429/324a0a6f/attachment.html
