[mapserver-users] PropertyIsLike in combination with AND
doesn't work (progress issue 3064)
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Aug 4 05:07:12 EDT 2010
Hi Geert,
as you can read in the bug report it was fixed in trunk as part of ticket
2720, so it should be working on trunk (since 6 months already).
Which platform are you on? What type of binaries are you using?
Best regards,
Bart
> hi list,
> As a Mapserver user I noticed that Mapserver does not accept a filter
> query where PropertyIsLike and AND are combined. In the issue tracker I
> read that this is a known issue (#3064). In the issue tracker I saw that
> there is a patch available, but that still some testing needs to be done
> on this patch. As I'm no programmer, unfortunately I can not perform the
> tests myself.
> Has anyone any knowledge if and when this patch will be available in
> Mapserver?
> Cheers,
> Geert
> mapserver-users at lists.osgeo.org
Looking for flexible support on OpenLayers or GeoExt? Please check out
http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
