[mapserver-users] Re: About shapefile generation in PHP with DBF
Cristiano Sumariva
sumariva at gmail.com
Mon Aug 9 13:13:06 EDT 2010
Yes I want data creation/conversion from a user interactive query generated
from a set of tables.
I maded some executions of ogr2ogr.
This tool looked as a good solution.
The problem is that the results may take long to execute( in case of a join
between two tables like 10 million rows history info and a 10 thousand
spatial feature table ).
I will first try execute this tool by launching a PHP monitor script process
using a shared memory buffer.
With the -progress flag i will try parse the output string to show some kind
of progress bar.
Put the monitor to sleep and in case of an abort/timeout from client kill
the ogr2ogr process and free system resources.
On client side I will pool server for status info.
2010/8/9 Sumit Sharma <sumit321 at hotmail.com>
> Although I not an expert of PHP, still I assume you are looking for tool
> for
> data conversion. I use ogr2ogr utility. It is GDAL utility and very
> effective as well. Hope this will serve the purpose.
> http://osgeo-org.1803224.n2.nabble.com/About-shapefile-generation-in-PHP-with-DBF-tp5381714p5388011.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100809/c468f7f4/attachment.html
