[mapserver-users] GeoRaster via gdal on Ubuntu
Lucena, Ivan
ivan.lucena at pmldnet.com
Wed Aug 11 07:23:08 EDT 2010
Sebastian,
Have you take a look on that page:
http://mapserver.org/installation/oracle.html
It is about GDAL/OGR/OCI but all the system settings experiments are applicable to GDAL/GeoRaster too.
Regards,
Ivan
Sebastian E. Ovide wrote:
> Hi All,
> I've installed MapServer via ubuntugis repo and build gdal by hand in
> order to support oracle
> sebas at SeansPC:~/mapserver$ /usr/lib/cgi-bin/mapserv -v
> MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> sebas at SeansPC:~/mapserver$ gdalinfo --version
> GDAL 1.7.2, released 2010/04/23
> sebas at SeansPC:~/mapserver$ gdalinfo --formats | grep GeoRaster
> GeoRaster (rw+): Oracle Spatial GeoRaster
> sebas at SeansPC:~/mapserver$ which gdalinfo
> /home/sebas/gdal/bin/gdalinfo
> now I'm trying to use MapServer with gdal to read GeoRasters but I'm
> getting this error:
> georaster:geoserver,geoserver,MFPRODUK_11G,LSLIDE_V5_RASTER,georaster,id=1
> and from command line:
> Driver: GeoRaster/Oracle Spatial GeoRaster
> Files: none associated
> Size is 24402, 49770
> Coordinate System is:
> PROJCS["British National Grid",
> GEOGCS["Ordnance Survey Great Brit",
> DATUM["Ordnance Survey Great Brit",
> SPHEROID["Airy
> 1830",6377563.396,299.3249646],375,-111,431,0,0,0,1],
> PRIMEM["Greenwich",0.000000],
> UNIT["Decimal Degree",0.01745329251994330]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["Scale_Factor",0.9996012717],
> PARAMETER["Central_Meridian",-2.000000],
> PARAMETER["Latitude_Of_Origin",49.000000],
> PARAMETER["False_Easting",400000.000000],
> PARAMETER["False_Northing",-100000.000000],
> UNIT["Meter",1.000000000000]]
> Origin = (49950.000000000000000,1250050.000000000000000)
> Pixel Size = (25.000000000000000,-25.000000000000000)
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> COMPRESSION=DEFLATE
> Corner Coordinates:
> Upper Left ( 49950.000, 1250050.000) ( 8d28'31.89"W, 60d58'39.59"N)
> Lower Left ( 49950.000, 5800.000) ( 6d52'14.32"W, 49d50'57.59"N)
> Upper Right ( 660000.000, 1250050.000) ( 2d49'4.15"E, 61d 2'50.13"N)
> Lower Right ( 660000.000, 5800.000) ( 1d37'14.80"E, 49d53'42.66"N)
> Center ( 354975.000, 627925.000) ( 2d42'48.98"W, 55d32'34.62"N)
> Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
> NoData Value=255
> Overviews: 12201x24885, 6100x12442, 3050x6221, 1525x3110, 762x1555,
> 381x777, 190x388, 95x194
> So I suspects that MapServer is using the wrong gdal...
> is gdal binding hardcoded into MapServer ? or MapServer would use gdal
> from the path ?
> Thanks
> Sebastian E. Ovide
> mapserver-users at lists.osgeo.org
