[mapserver-users] Re: GeoRaster via gdal on Ubuntu
Sebastian E. Ovide
sebastian.ovide at gmail.com
Wed Aug 11 10:47:01 EDT 2010
Hi Daniel,
gdal is in my home dir...
sebas at SeansPC:~/public_html/workshop-5.4$ echo $LD_LIBRARY_PATH
/u01/app/oracle/product/11.2.0/dbhome_1/lib:/home/sebas/gdal/lib
sebas at SeansPC:~/public_html/workshop-5.4$ ldd
/usr/lib/cgi-bin/mapserv-custom | grep gdal
libgdal.so.1 => /home/sebas/gdal/lib/libgdal.so.1
(0x00007fc005571000)
sebas at SeansPC:~/public_html/workshop-5.4$ cat
/etc/apache2/sites-enabled/000-default
<Location "/cgi-bin/">
SetEnv ORACLE_HOME "/u01/app/oracle/product/11.2.0/dbhome_1"
SetEnv TNS_ADMIN "/home/sebas/gdal/"
SetEnv LD_LIBRARY_PATH
"/u01/app/oracle/product/11.2.0/dbhome_1/lib:/home/sebas/gdal/lib"
SetEnv PATH
"/home/sebas/gdal/src/swig/python/scripts:/u01/app/oracle/product/11.2.0/dbhome_1/bin:/home/sebas/gdal/bin:/home/sebas/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin"
</Location>
On Wed, Aug 11, 2010 at 2:26 PM, Daniel Morissette <dmorissette at mapgears.com
> wrote:
> Where is the new GDAL lib installed? Did you update your runtime libpath
> to point to the new GDAL lib location? And if so how ? (LD_LIBRARY_PATH
> or ld.so.conf?)
> If you used LD_LIBRARY_PATH, then you need to make sure the value is
> passed to your CGIs by Apache by adding a "PassEnv LD_LIBRARY_PATH"
> directive to your httpd.conf.
> Also, you can use the command "ldd mapserv-custom" to determine which
> copy of libgdal.so is being used.
> Daniel
> Sebastian E. Ovide wrote:
> > I have just built MapServer... just in case..
> > ./configure --with-gdal=/home/sebas/gdal/bin/gdal-config
> > make
> > sebas at SeansPC:~/mapserver/mapserver-5.6.5$ ./mapserv -v
> > MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > OUTPUT=SVG SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV INPUT=EPPL7
> > INPUT=GDAL INPUT=SHAPEFILE
> > cd /usr/lib/cgi-bin/
> > ln -s /home/sebas/mapserver/mapserver-5.6.5/mapserv mapserv-custom
> > and changed index.html to point to mapserv-custom
> > the problem is still there...
> > any other ideas ?
> > On Wed, Aug 11, 2010 at 11:33 AM, Sebastian E. Ovide
> > <sebastian.ovide at gmail.com <mailto:sebastian.ovide at gmail.com>> wrote:
> > Hi All,
> > I've installed MapServer via ubuntugis repo and build gdal by hand
> > in order to support oracle
> > sebas at SeansPC:~/mapserver$ /usr/lib/cgi-bin/mapserv -v
> > OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> > SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
> > SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> > SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> > SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG
> > INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > sebas at SeansPC:~/mapserver$ gdalinfo --version
> > GDAL 1.7.2, released 2010/04/23
> > sebas at SeansPC:~/mapserver$ gdalinfo --formats | grep GeoRaster
> > GeoRaster (rw+): Oracle Spatial GeoRaster
> > sebas at SeansPC:~/mapserver$ which gdalinfo
> > /home/sebas/gdal/bin/gdalinfo
> > now I'm trying to use MapServer with gdal to read GeoRasters but I'm
> > getting this error:
> georaster:geoserver,geoserver,MFPRODUK_11G,LSLIDE_V5_RASTER,georaster,id=1
> > and from command line:
> > Driver: GeoRaster/Oracle Spatial GeoRaster
> > Files: none associated
> > Size is 24402, 49770
> > Coordinate System is:
> > PROJCS["British National Grid",
> > GEOGCS["Ordnance Survey Great Brit",
> > DATUM["Ordnance Survey Great Brit",
> > SPHEROID["Airy
> > 1830",6377563.396,299.3249646],375,-111,431,0,0,0,1],
> > PRIMEM["Greenwich",0.000000],
> > UNIT["Decimal Degree",0.01745329251994330]],
> > PROJECTION["Transverse_Mercator"],
> > PARAMETER["Scale_Factor",0.9996012717],
> > PARAMETER["Central_Meridian",-2.000000],
> > PARAMETER["Latitude_Of_Origin",49.000000],
> > PARAMETER["False_Easting",400000.000000],
> > PARAMETER["False_Northing",-100000.000000],
> > UNIT["Meter",1.000000000000]]
> > Origin = (49950.000000000000000,1250050.000000000000000)
> > Pixel Size = (25.000000000000000,-25.000000000000000)
> > Image Structure Metadata:
> > INTERLEAVE=PIXEL
> > COMPRESSION=DEFLATE
> > Corner Coordinates:
> > Upper Left ( 49950.000, 1250050.000) ( 8d28'31.89"W,
> 60d58'39.59"N)
> > Lower Left ( 49950.000, 5800.000) ( 6d52'14.32"W,
> 49d50'57.59"N)
> > Upper Right ( 660000.000, 1250050.000) ( 2d49'4.15"E, 61d
> 2'50.13"N)
> > Lower Right ( 660000.000, 5800.000) ( 1d37'14.80"E,
> 49d53'42.66"N)
> > Center ( 354975.000, 627925.000) ( 2d42'48.98"W,
> 55d32'34.62"N)
> > Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
> > NoData Value=255
> > Overviews: 12201x24885, 6100x12442, 3050x6221, 1525x3110,
> > 762x1555, 381x777, 190x388, 95x194
> > So I suspects that MapServer is using the wrong gdal...
> > is gdal binding hardcoded into MapServer ? or MapServer would use
> > gdal from the path ?
> > Thanks
> > Sebastian E. Ovide
> > Sebastian E. Ovide
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Daniel Morissette
> http://www.mapgears.com/
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100811/ca104d80/attachment.html
