[mapserver-users] Openlayers + Bing Maps with Mapserver WMS	projection error...
    Edward Mac Gillavry
    emacgillavry at hotmail.com
    Wed Aug 11 08:35:56 PDT 2010
Bing maps is also using EPSG: 900913, EPSG:3785 or EPSG:3857 whichever is the latest... That should do the trick.
HTH
Edward
Date: Wed, 11 Aug 2010 11:12:47 -0300
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Openlayers + Bing Maps with Mapserver WMS	projection error...
Hey guys...
When using Bing maps as base layer, I have huge difference between my data ... Both are using WGS84 projection...
The image is attached...
Any idea?
Thanks
My WMS map:
MAP
  PROJECTION
        "+init=epsg:4326"
  END
 WEB
        IMAGEPATH 'D:\Temp'
        IMAGEURL '/tmp/'
        QUERYFORMAT 'text/html'
        METADATA
            "wms_title"     "WMS Server"  ##required
            "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe?"   ##required
            "wms_srs"       "EPSG:4269 EPSG:4326 EPSG:42304 EPSG:42101 EPSG:900913"  ##recommended
            "wms_feature_info_mime_type" "text/html"
            "labelcache_map_edge_buffer"
  "-10"
        END
    END
LAYER
        NAME STATE
        METADATA
            "wms_title"    "STATE"   ##required
        END
        TYPE polygon
        STATUS ON
        INCLUDE "Connection.map"
        DATA "..."
        PROCESSING "CLOSE_CONNECTION=DEFER"
        PROCESSING "LABEL_NO_CLIP=ON"
        PROJECTION
            "init=epsg:4326"
        END
My Openlayers config:
 map = new OpenLayers.Map('Test', {
         resolutions: [0.09524345064126273, 0.0730199788249681,
0.047621725320631365, 0.031747816880420915, 0.015873908440210457,
0.009524345064126272, 0.0031747816880420914, 0.0015873908440210457,
0.0007936954220105228, 0.00031747816880420915],
        projection: "EPSG:4326",
        displayProjection: new OpenLayers.Projection("EPSG:4326"),
        tileSize: new OpenLayers.Size(400, 400),
        maxExtent: new OpenLayers.Bounds(-102.2607421875, -46.142578125, 4.7021484375, 13.623046875)
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100811/ca5b6805/attachment.htm>
More information about the MapServer-users
