[mapserver-users] MrSID How To
Simone Frigerio
simone.frigerio at univie.ac.at
Wed Aug 11 16:28:36 EDT 2010
I tested gdal and it support MrSID format, but sometimes it didn't work.
The reason should be Windows OS or original type of raster (before the
compression in .sid format). Inmy case the problem was for 3-bands aerial
images.
I solved the problem with .ecw format, similar as compression rate and
quality result.
Hope that helps.
Simone
On Wed, August 11, 2010 21:47, Moen, Paul T. wrote:
> LAYER
> GROUP "Raster Images"
> TYPE RASTER
> NAME "MrSid"
> STATUS ON
> DATA "sidfile.sid"
> END
> Your version of gdal must support the MrSID format.
> To find out, type the command 'gdal_translate --formats' to see if it
> does. This command works on Linux and Mac (Unix). I don't know if it will
> work with Windows. Someone that uses Windows should be able to tell you.
> Supported Formats:
> MrSID (ro): Multi-resolution Seamless Image Database (MrSID)
> Hope that helps,
> Paul
> On Aug 11, 2010, at 2:02 PM, Eric Weisbender wrote:
> Does anyone have any how to or layer definition documentation for MrSID's
> in MapServer.
> Thanks,
> EW
> mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Simone Frigerio
Department of Geography and Regional Research
University of Vienna
Universitaetsstr. 7
A-1010 Vienna
AUSTRIA
