[mapserver-users] What's wrong with Path Relative?
elisabeth theresia
dbee_kawai at yahoo.com
Thu Aug 12 15:39:31 EDT 2010
Hi all helpers,
it makes me confuse when i used
http://localhost/cgi-bin/mapserv.exe?map=i:/Spatial/mapfile/kec_lbl.map&layers=all&mode=map
it appear the map (with absolute path)
then, when i change folder (Chameleon framework) and change mapfile withRelative
Path and checking :
http://localhost/cgi-bin/mapserv.exe?map=i:/ms4w/apps/appweb/map/kec_lbl.map&layers=all&mode=map
APPEAR error:
msDrawMap(): Image handling error. Failed to draw layer named 'Kecamatan'.
msSHPOpenFile(): Unable to access file. (i:/ms4w/apps/appweb/map/Kecamatan)
(i:/ms4w/apps/appweb/map/../shp/Kecamatan)
Here the STRUCTURE of FOLDER:
i:
-ms4w
-apps
-htdocs(Template .html, .phtml)
-appweb
-map (all map stored here)
-shp (all shp stored here)
-etc(fonts)
MAPFILE:
MAP
NAME Kecamatan
IMAGETYPE PNG
EXTENT -123.950500 -183.224900 299.457000 145.260600
STATUS ON
UNITS DD
SIZE 546 388
IMAGECOLOR 255 255 255
SHAPEPATH "../shp" #??? Is it TRUE??
FONTSET "../etc/font.dat"
WEB
IMAGEPATH "./temp/"
IMAGEURL "./temp/"
END
#PENDEFINISIAN LAYER
LAYER
NAME Kecamatan
DATA Kecamatan
STATUS DEFAULT
TYPE POLYGON
CLASS
NAME "Kecamatan"
STYLE
COLOR 179 243 251
OUTLINECOLOR 0 0 0
END #STYLE
END #CLASS
END # DEFINISI LAYER
LAYER
NAME "Anotasi"
DATA Kecamatan
STATUS ON
TYPE annotation # asalnya tipe poligon
LABELITEM "kecamatan"
CLASS
LABEL
COLOR 0 0 0
TYPE Truetype
FONT Arial
SIZE 11
MINSIZE 8
ANGLE Auto
POSITION UC
ANTIALIAS True
END # LABEL
END #CLASS
END #LAYER
END #MAP
Thanks alot Helpers,
-dbee
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100812/9fca5925/attachment.html
