Re: [mapserver-users] logging GDAL queries
Ivan Lucena
ivan.lucena at pmldnet.com
Fri Aug 13 08:59:25 EDT 2010
Sebastian,
You are using a very small block size, maybe because you are also using ArcGIS products and they only support Oracle GeoRaster with 256x256 blocking. Is that right?
Because of that, to access your GeoRaster object, the GDAL driver is requesting a very large array of BLOB (1000000 approximately). That can make your sever such-up memory from the machine where it is running and it is probably using virtual memory (disk) what is really slow. It also uses some memory on the client side just to hold the array too but if you are running everything (Mapserver,Oracle) on the same machine that will adds up.
We are aware of that problem but it would be very helpful if you could file a bug report on GDAL's trac [http://trac.osgeo.org/gdal/] Thanks.
Just as curiosity. Did you loaded that image with gdal_translate? How long it took and long does it takes to generate pyramids? Ha, you forgot to say what version of Oracle you are using.
Best regards,
Ivan
> -------Original Message-------
> From: Sebastian E. Ovide <sebastian.ovide at gmail.com>
> To: Lucena, Ivan <ivan.lucena at pmldnet.com>
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] logging GDAL queries
> Sent: Aug 13 '10 06:44
> sure...
> sebas at SeansPC:~/mapserver/mapserver-5.6.5$ gdalinfo --version
> GDAL 1.7.2, released 2010/04/23
> georaster:geoserver,geoserver,MFPRODUK_11G,fluvd04q200pj,georaster,id=1
> -mdd oracle
> Driver: GeoRaster/Oracle Spatial GeoRaster
> Files: none associated
> Size is 190325, 271423
> Coordinate System is:
> PROJCS["Popular Visualisation CRS / Mercator (deprecated)",
> GEOGCS["Popular Visualisation CRS",
> DATUM["Popular_Visualisation_Datum",
> SPHEROID["Popular Visualisation Sphere",6378137,0,
> AUTHORITY["EPSG","7059"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6055"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.01745329251994328,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4055"]],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> PROJECTION["Mercator_1SP"],
> PARAMETER["central_meridian",0],
> PARAMETER["scale_factor",1],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
> +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext
> +no_defs"],
> AUTHORITY["EPSG","3785"],
> AXIS["X",EAST],
> AXIS["Y",NORTH]]
> Origin = (-703633.464883987908252,7805920.616936270147562)
> Pixel Size = (4.999999999999999,-5.000000000000000)
> Metadata (oracle):
> TABLE_NAME=fluvd04q200pj
> COLUMN_NAME=georaster
> RDT_TABLE_NAME=RDT_FLUVD04Q200PJ
> RASTER_ID=62
> METADATA=<georasterMetadata xmlns="[LINK:
> http://xmlns.oracle.com/spatial/georaster]
> http://xmlns.oracle.com/spatial/georaster">
> <objectInfo>
> <rasterType>20001</rasterType>
> <isBlank>false</isBlank>
> <defaultRed>1</defaultRed>
> <defaultGreen>1</defaultGreen>
> <defaultBlue>1</defaultBlue>
> </objectInfo>
> <rasterInfo>
> <cellRepresentation>UNDEFINED</cellRepresentation>
> <cellDepth>8BIT_U</cellDepth>
> <NODATA>255</NODATA>
> <totalDimensions>2</totalDimensions>
> <dimensionSize type="ROW">
> <size>271423</size>
> </dimensionSize>
> <dimensionSize type="COLUMN">
> <size>190325</size>
> </dimensionSize>
> <ULTCoordinate>
> <row>0</row>
> <column>0</column>
> </ULTCoordinate>
> <blocking>
> <type>REGULAR</type>
> <totalRowBlocks>1061</totalRowBlocks>
> <totalColumnBlocks>744</totalColumnBlocks>
> <rowBlockSize>256</rowBlockSize>
> <columnBlockSize>256</columnBlockSize>
> </blocking>
> <interleaving>BIP</interleaving>
> <pyramid>
> <type>DECREASE</type>
> <resampling>NN</resampling>
> <maxLevel>11</maxLevel>
> </pyramid>
> <compression>
> <type>DEFLATE</type>
> </compression>
> </rasterInfo>
> <spatialReferenceInfo>
> <isReferenced>true</isReferenced>
> <isRectified>true</isRectified>
> <SRID>3785</SRID>
> <spatialResolution dimensionType="X">
> <resolution>5</resolution>
> </spatialResolution>
> <spatialResolution dimensionType="Y">
> <modelCoordinateLocation>CENTER</modelCoordinateLocation>
> <modelType>FunctionalFitting</modelType>
> <polynomialModel rowOff="0" columnOff="0" xOff="0" yOff="0" zOff="0"
> rowScale="1" columnScale="1" xScale="1" yScale="1" zScale="1">
> <pPolynomial pType="1" nVars="2" order="1" nCoefficients="3">
> <polynomialCoefficients>1561183.623387254 0
> -0.2</polynomialCoefficients>
> </pPolynomial>
> <qPolynomial pType="1" nVars="0" order="0" nCoefficients="1">
> <polynomialCoefficients>1</polynomialCoefficients>
> </qPolynomial>
> <rPolynomial pType="1" nVars="2" order="1" nCoefficients="3">
> <polynomialCoefficients>140726.1929767976 0.2
> 0</polynomialCoefficients>
> </rPolynomial>
> <sPolynomial pType="1" nVars="0" order="0" nCoefficients="1">
> </sPolynomial>
> </polynomialModel>
> </spatialReferenceInfo>
> <layerInfo>
> <layerDimension>BAND</layerDimension>
> <objectLayer>
> <layerNumber>0</layerNumber>
> <layerDimensionOrdinate>0</layerDimensionOrdinate>
> <layerID/>
> <colorMap>
> <colors>
> <cell value="1" red="255" green="0" blue="0"
> alpha="100"/>
> <cell value="2" red="0" green="255" blue="0"
> alpha="100"/>
> <cell value="3" red="0" green="0" blue="255"
> alpha="100"/>
> <cell value="4" red="150" green="50" blue="100"
> alpha="100"/>
> <cell value="255" red="0" green="0" blue="0" alpha="0"/>
> </colors>
> </colorMap>
> </objectLayer>
> </layerInfo>
> </georasterMetadata>
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> COMPRESSION=DEFLATE
> Corner Coordinates:
> Upper Left ( -703633.465, 7805920.617) ( 6d19'15.05"W, 57d
> 2'52.80"N)
> Lower Left ( -703633.465, 6448805.617) ( 6d19'15.05"W,
> 49d49'30.04"N)
> Upper Right ( 247991.535, 7805920.617) ( 2d13'39.89"E, 57d
> 2'52.80"N)
> Lower Right ( 247991.535, 6448805.617) ( 2d13'39.89"E,
> 49d49'30.04"N)
> Center ( -227820.965, 7127363.117) ( 2d 2'47.58"W,
> 53d35'23.19"N)
> Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
> NoData Value=255
> Overviews: 95162x135711, 47581x67855, 23790x33927, 11895x16963,
> 5947x8481, 2973x4240, 1486x2120, 743x1060, 371x530, 185x265, 92x132
> On Fri, Aug 13, 2010 at 12:32 PM, Lucena, Ivan <[LINK:
> mailto:ivan.lucena at pmldnet.com] ivan.lucena at pmldnet.com> wrote:
> Interesting.
> Can you post your gdalinfo report with "-mdd oracle" option?
> What are the versions your are running (GDAL,Oracle)?
> Older version of the driver used to run a new query every time you change
> levels.
> Sebastian E. Ovide wrote:
> yep I did... and the weir thing is that generating the images from "far
> away" zoom under 12... it performs very well... not sure why it doesn't
> in the levels 13-17.... for that reason I was trying to find the SQL
> queries....
> On Fri, Aug 13, 2010 at 12:01 PM, Lucena, Ivan <[LINK:
> mailto:ivan.lucena at pmldnet.com] ivan.lucena at pmldnet.com <mailto:[LINK:
> mailto:ivan.lucena at pmldnet.com] ivan.lucena at pmldnet.com>> wrote:
> Sebastian,
> Hi All
> I am using MapServer + GDAL to render GeoRasters and I am
> having
> very poor performance reading GeoRasters at a high zoom
> level...
> over 13... it would take even 20 seconds per tile...
> Did you generate pyramids?
> Is it possible to log the GDAL queries that MapServer is
> doing?
> (and the SQL queries that GDAL is doing ?)
> thanks
> -- Sebastian E. Ovide
> [LINK: mailto:mapserver-users at lists.osgeo.org]
> <mailto:[LINK: mailto:mapserver-users at lists.osgeo.org]
> mapserver-users at lists.osgeo.org>
> [LINK:
> http://lists.osgeo.org/mailman/listinfo/mapserver-users]
> Sebastian E. Ovide
> Sebastian E. Ovide
