[mapserver-users] logging GDAL queries
Lucena, Ivan
ivan.lucena at pmldnet.com
Sat Aug 14 08:47:31 EDT 2010
Sebastian,
Sebastian E. Ovide wrote:
> Hi Ivan,
> Because of that, to access your GeoRaster object, the GDAL driver is
> requesting a very large array of BLOB (1000000 approximately). T
> I do not know how <apServer/GDAL works, but I cannot understand this query:
> [Fri Aug 13 13:53:00 2010] [error] [client 10.0.1.40] SELECT RASTERBLOCK
> [Fri Aug 13 13:53:00 2010] [error] [client 10.0.1.40] FROM
> RDT_FLUVD04Q200PJ
> [Fri Aug 13 13:53:00 2010] [error] [client 10.0.1.40] WHERE RASTERID =
> :1 AND
> PYRAMIDLEVEL = :3
> [Fri Aug 13 13:53:00 2010] [error] [client 10.0.1.40] ORDER BY
> BANDBLOCKNUMBER ASC,
> ROWBLOCKNUMBER ASC,
> COLUMNBLOCKNUMBER ASC
> It looks like MapServer/GDAL is trying to read the whole pyramid level
> X of the table RDT_FLUVD04Q200PJ ?
> Am I right ?
> at level 0 it would read the whole raster !!!!
Yes!
and
No!
That query creates a *cursor* to go through the whole raster, meaning, all the rows on the
RasterDataTable that satisfy that query in the order stipulated by it.
It does require a some memory but it looks like you got it. Right? I assuming that because you said
that gdal_translate loaded those 51 Gb in 5 minutes.
By the way, how long does it take to produce a geotiff file? Have loaded that image on QuantumGIS
using the oracle_raster plugin? Hoes does it perform?
> I was expecting to find in the logs some query that reads a subset of
> the whole image (just the tile/metatile that MapServer is serving) for
> example using SDO_GEOR.getRasterSubset..
That would be very slow. The GDAL driver access the BLOB directly.
I have more questions:
Are you using Mapserver FastCGI with a recent version?
If you do, them the process will remains in memory, the GDALDataset associated with that GeoRaster
will be keet, the *cursor* you remain alive and all the zooms and pans are going to work faster.
Like for QGIS. Unless, of course, Mapserver is feeling the need to re-project or produce a new
overview tiles on the fly. Can you see that on the log?
Regards,
Ivan
