[mapserver-users] Load web error in Map server.
Gupta
gupta532 at gmail.com
Mon Aug 16 02:27:52 EDT 2010
Hi all,
I am new to MAp server . i understood mapserver functionalities using the
tutorial.now i want to create a map using image and shape file.when tried to
use it.i am getting following error.
loadWeb(): General error message. URL-based TEMPLATE configuration failed
pattern validation. msEvalRegex(): Regular expression error. String
(basic.html) failed expression test.
my local URL is:
http://127.0.0.1/cgi-bin/mapserv.exe?map=c:/ms4w2/apps/tutorial/htdocs/basic.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+basic.html
actually i changed example2.2 file to basic.and in mapfile i placed my
image.
please let me know what i need to change to get output.
Thanks and Regards,
Kishor Gupta.
Project Engineer,
CDAC,Bangalore,
INDIA.
Ph.no:09538722172
If a drop of water falls on lake, it loses its identity.
If it falls on a rose, it shines.
If it falls on a shell, it becomes a pearl.
The drop is the same but the company matters
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100816/ef9c3e24/attachment.html
