[mapserver-users] Load web error in Map server.
Wim Vanbelle
wimvanbelle at gmail.com
Mon Aug 16 02:54:08 EDT 2010
Do you want the map to be displayed in a html page, or do you just need the
pic?
In the latter case, you could try to just query the following link:
http://127.0.0.1/cgi-bin/mapserv.exe?map=c:/ms4w2/apps/tutorial/htdocs/basic.map&layer=states&mode=map<http://127.0.0.1/cgi-bin/mapserv.exe?map=c:/ms4w2/apps/tutorial/htdocs/basic.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+basic.html>
I also suggest you use the typical hello world to test and try your
mapserver (and get a feel for it). Depending on what your ultimate goal is,
you may or may not need the web templates at all.
This would be a simple sample of a hello world map:
MAP
NAME "Hello_World"
SIZE 400 300
IMAGECOLOR 249 245 186
IMAGETYPE png
EXTENT -1.00 -1.00 1.00 1.00
LAYER
STATUS default
TYPE point
FEATURE
POINTS 0.0 0.0 END
TEXT "Hello World"
END # end feature
CLASS
STYLE
COLOR 255 0 0
END
LABEL
TYPE bitmap
END
END
END
END
Considering its named hello.map, you'd get an image by browsing to
http://127.0.0.1/cgi-bin/mapserv.exe?map=c:/ms4w2/apps/helloworld/hello.map&mode=map<http://127.0.0.1/cgi-bin/mapserv.exe?map=c:/ms4w2/apps/tutorial/htdocs/basic.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+basic.html>
(Don't forget to add the helloworld map in the apps directory)
On 16 August 2010 08:27, Gupta <gupta532 at gmail.com> wrote:
> Hi all,
> I am new to MAp server . i understood mapserver functionalities using the
> tutorial.now i want to create a map using image and shape file.when tried to
> use it.i am getting following error.
> loadWeb(): General error message. URL-based TEMPLATE configuration failed
> pattern validation. msEvalRegex(): Regular expression error. String
> (basic.html) failed expression test.
> my local URL is:
> actually i changed example2.2 file to basic.and in mapfile i placed my
> image.
> please let me know what i need to change to get output.
> Thanks and Regards,
> Kishor Gupta.
> Project Engineer,
> CDAC,Bangalore,
> INDIA.
> Ph.no:09538722172
> If a drop of water falls on lake, it loses its identity.
> If it falls on a rose, it shines.
> If it falls on a shell, it becomes a pearl.
> The drop is the same but the company matters
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100816/57b33d17/attachment.html
