Re: [mapserver-users] logging GDAL queries
Ivan Lucena
ivan.lucena at pmldnet.com
Mon Aug 16 14:23:30 EDT 2010
Sebastian,
> the performance has not improved. Why should it ? the extra pyramid
> levels contains 46x66, 23x33, 11x16, 5x8, 2x4, 1x2.... but the problems
> that I am having are for 95162x135711, 47581x67855, 23790x33927,
> 11895x16963... that are low pyramid levels... (ie: high zoom=low pyramid
> level)...
If you are still having problem with MapViewer I suggest you to post your log at [http://forums.oracle.com/forums/forum.jspa?forumID=727]. Any improvement on MapServer+GeoRaster through GDAL would take a little bit of time to adapt the initial ETL design.
Regards,
Ivan
