[mapserver-users] Build 5.6.5 with AGG, weird error
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Aug 17 13:16:23 EDT 2010
Gregor at HostGIS wrote:
> Hey Stephen, nice to hear from you. :)
>> You should not need to download, build and install agg anymore.
> Sounds good. I have uninstalled it; that is, deleted libagg.a and the
> include files.
> But that doesn't solve the build issue. I still get that linking error:
> `.gnu.linkonce.t._ZN9mapserver18rasterizer_sl_clipINS_12ras_conv_intEE7line_toINS_19rasterizer_cells_aaINS_7cell_aaEEEEEvRT_ii'
> referenced in section `.rodata' of
> ./libmapserver.a(agg_font_freetype.o): defined in discarded section
> of ./libmapserver.a(agg_font_freetype.o)
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
Hi Gregor,
In your mapserver build dir do:
make clean
./configure ....
make
also check to see if you have an errand mapserver.a somewhere
locate mapserver.a
and remove them.
-Steve
