[mapserver-users] Re: maps all look squished
Josh Jordan
outerspaceman81 at yahoo.com
Fri Aug 20 11:07:03 EDT 2010
I have 8 shapefiles, only the states shapefiles returns a projection from ogrinfo. It returns:
GEOGCS["GCS_North_American_1983", DATUM["North_American_Datum_1983", SPHEROID["GRS_1980",6378137.0,298.257222101]], PRIMEM["Greenwich",0.0], UNIT["Degree",0.0174532925199433]]
It fails if I paste that directly into my mapfile, changing the projection to NAD83 michigan, "EPSG 2252", makes no noticeable difference, a screen shot of the map lines up exactly with the squished maps from before.
--- On Fri, 8/20/10, Sumit Sharma <sumit321 at hotmail.com> wrote:
Subject: [mapserver-users] Re: maps all look squished
To: mapserver-users at lists.osgeo.org
Date: Friday, August 20, 2010, 10:46 AM
it could be projection problem. Have you tried ogrinfo on your dataset? it
will give you correct projection and extents of layer. For debugging
purposes just try to draw one layer with whatever information you get from
ogrinfo.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/maps-all-look-squished-tp5444218p5444766.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100820/2105e7d0/attachment.html
