[mapserver-users] Mapserver tile generation - google maps
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Aug 24 00:45:03 EDT 2010
If you are using mode=tile, then this is a known limitation on the
mapserver side. There is a plan for 6.0 to add tilecache support to
mapserver that would allow you to generate meta tiles and chop the tiles
into a tilecache which is the way to resolve the artifacts you are seeing.
http://trac.osgeo.org/mapserver/ticket/3513
You can add yourself the CC on this bug if you want to follow it. There
is also an RFC for the mode=tile which I don't have handy that should
give you more information on the limitations and feature of that.
Hope this helps,
-Steve W
On 8/24/2010 12:34 AM, Lime, Steve D (DNR) wrote:
> What mapserver version, what graphics driver? Is this using
> mode=tile?
> Steve ________________________________________ From:
> mapserver-users-bounces at lists.osgeo.org
> [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Wim Vanbelle
> [wimvanbelle at gmail.com] Sent: Friday, August 20, 2010 6:26 AM To:
> mapserver-users at lists.osgeo.org Subject: [mapserver-users] Mapserver
> Hi all,
> I noticed a similar post regarding symbol issues, but there was no
> solution. My Google maps tiles are currently clipped at the tile
> itself. This results in rather unwanted behaviour:
> http://fileshare.myroute.be/exchange/Capture.PNG
> I'm not 100% sure that this is mapservers' 'issue' , or google maps
> issue.
> If anyone would have further tips to spice up the graphics even more,
> I'd be more than glad to hear them :).
> Thanks. Wim _______________________________________________
> mapserver-users mailing list mapserver-users at lists.osgeo.org
