[mapserver-users] Feature select performance
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Aug 24 09:27:55 EDT 2010
How is the selection done? How is the highlighting done? Those processes will really impact performance depending on how things are implemented.
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Chris Jackson [webturtles at gmail.com]
Sent: Tuesday, August 24, 2010 3:19 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Feature select performance
Hi all
I have rigged up a webGIS app (P.Mapper framework) where one of the underlying datasets is a model grid (many thousand cells) in a shapefile. The data displays nice and quick when just viewing, but if I allow the user to select say 5000 cells it is very (extremely) slow to redraw with the highlighted cells. Doing the same task in a very old ArcGIS server web app was much quicker (admittedly the data was in SDE/MS SQL). So my question is what is the best way to improve performance - would just transferring the shapefile to to say a MS SQL 2005 db with the MSSQLSPATIAL add-on be a good step or is there are better way to present the data in the Map file?
Many thanks
Chris
