[mapserver-users] RGBA transparent images?
Wim Vanbelle
wimvanbelle at gmail.com
Wed Aug 25 07:23:40 EDT 2010
Erm, pick interlace=false instead. That was just a test and I forgot to put
that back
On 25 August 2010 13:22, Wim Vanbelle <wimvanbelle at gmail.com> wrote:
> Hi Steve,
> I have this in my file:
> OUTPUTFORMAT
> NAME "AGGPNG"
> DRIVER "AGG/PNG"
> EXTENSION "png"
> MIMETYPE "image/png;mode=24bit;"
> IMAGEMODE RGBA
> FORMATOPTION "INTERLACE=true"
> FORMATOPTION "QUANTIZE_NEW=ON"
> FORMATOPTION "QUANTIZE_FORCE=ON"
> FORMATOPTION "QUANTIZE_DITHER=ON"
> FORMATOPTION "QUANTIZE_COLORS=256"
> END
> And in my layer, if you want opacity:
> OPACITY 60
> That should render nice lines :).
> On 24 August 2010 21:16, Stephen Woodbridge <woodbri at swoodbridge.com>wrote:
>> If I want to generate RGBA transparent images using AGG, what should my
>> OUTPUTFORMAT block look like?
>> I was using this one for 8-bit images, but the anti aliasing was creating
>> blackish artifacts along the rendered lines. Is there a way to avoid them?
>> OUTPUTFORMAT
>> NAME "agg_qn"
>> DRIVER "AGG/PNG"
>> EXTENSION "png"
>> MIMETYPE "image/png"
>> IMAGEMODE RGBA
>> TRANSPARENT ON
>> FORMATOPTION "INTERLACE=false"
>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>> FORMATOPTION "QUANTIZE_COLORS=37"
>> FORMATOPTION "TRANSPARENT=ON"
>> END
>> Trying 32bit RGBA:
>> IMAGECOLOR 0 0 0
>> OUTPUTFORMAT
>> NAME "agg_qn"
>> DRIVER "AGG/PNG"
>> EXTENSION "png"
>> IMAGEMODE RGBA
>> TRANSPARENT ON
>> END
>> Generated black backgrounds and not transparent. Is it as simple as
>> removing the IMAGECOLOR? I didn't try that.
>> -Steve W
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100825/2b066a58/attachment.html
