[mapserver-users] Tile mode & multiple layers
Wim Vanbelle
wimvanbelle at gmail.com
Wed Aug 25 08:51:58 EDT 2010
Hi Clément,
Under your MAP you can specify an OUTPUTFORMAT tag.
See http://mapserver.org/mapfile/outputformat.html for details. There's also
some additional information about the format options at the bottom.
Use AGG for best quality results.
On 25 August 2010 14:37, Clément MONIER <Clement.MONIER at v-trafic.com> wrote:
> Thanks a lot !
> I have another bothering issue :
> PNG outputs of my MS CGI requests now don’t look nicely rendered any more
> (i.e no smoothly antialiased AGG display)
> http://localhost/cgi-bin/mapserv.exe?mode=tile&tilemode=gmap&tile=X+Y+S&map=mymapfile.map&LAYERS=layer1
> layer2<http://localhost/cgi-bin/mapserv.exe?mode=tile&tilemode=gmap&tile=X+Y+S&map=mymapfile.map&LAYERS=layer1%20layer2>
> as it was with similar WMS requests targeting the same mapfile though
> Where should I specify the desired output format ?
> Thank you for your help
> *De :* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *De la part de* Wim Vanbelle
> *Envoyé :* mercredi 25 août 2010 13:50
> *À :* mapserver-users at lists.osgeo.org
> *Objet :* Re: [mapserver-users] Tile mode & multiple layers
> Hi Clément,
> Your request is wrong ;).
> Try using a space instead. Take a look here :
> http://mapserver.org/output/tile_mode.html
> Good luck.
> On 25 August 2010 13:47, Clément MONIER <Clement.MONIER at v-trafic.com>
> wrote:
> Hi,
> I’m facing a (probable widely encountered) problem using MapServer with
> tile-mode option.
> It seems like multiple layers aren’t allowed ??
> http://localhost/cgi-bin/mapserv.exe?mode=tile&tilemode=gmap&tile=X+Y+S&map=mymapfile.map&LAYERS=layer1=> ok
> http://localhost/cgi-bin/mapserv.exe?mode=tile&tilemode=gmap&tile=X+Y+S&map=mymapfile.map&LAYERS=layer2=> ok
> http://localhost/cgi-bin/mapserv.exe?mode=tile&tilemode=gmap&tile=X+Y+S&map=mymapfile.map&LAYERS=layer1,layer2=> ko !
> Why ?
> Thanks & Regards
> *Clément *
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100825/f510facb/attachment.html
