[mapserver-users] RE: How to appear Graph?
Sumit Sharma
sumit321 at hotmail.com
Fri Aug 27 11:18:46 EDT 2010
You really need to upgrade your version Theresia !!! If you follow docuementation and use appropriate version of mapserver I think you should be fine.
-Sumit
Date: Fri, 27 Aug 2010 05:36:14 -0700
From: ml-node+5469290-1725509796-96454 at n2.nabble.com
To: sumit321 at hotmail.com
Subject: Re: How to appear Graph?
hey Mr. Thomas and Mr. Sumit,
Lol, i use Mapserver vs 1.6.... oh No.... :(
Then i can't appear MapServer ya??
If i change Mapserver version is that any special setting that should i do??
Thanks
-Theresia
To: elisabeth theresia <[hidden email]>
Cc: mapserv forumlist <[hidden email]>
Sent: Thu, August 26, 2010 10:59:42 PM
Subject: Re: [mapserver-users] Re: How to appear Graph?
What version of MapServer are you using? Charting appeared in 5.0.
Regards,
Thomas
On Aug 26, 2010 9:02 PM, "elisabeth theresia" <[hidden email]> wrote:
Hi Mr. Sumit,
Thanks for your advice. when i tried to apply step by step from: http://mapserver.org/output/dynamic_charting.html
then in the browser said:
getSymbol(): Symbol definition error. Parsing error near (CHART):(line 66)
this is line 66:
TYPE CHART
why become like this?
here the mapfile:
###############CHART############## LAYER NAME "chart bj" STATUS ON #TYPE POLYGON TYPE CHART PROCESSING "CHART_TYPE=BAR" PROCESSING "CHART_SIZE=20 10" #specify size of the chart for pie or bar graphs #PROCESSING "CHART_SIZE=20 10" #specify width n height for graphs CONNECTIONTYPE POSTGIS CONNECTION "user=dbee password=root dbname=dbSpatialSura host=localhost port=5432" DATA "the_geom FROM tbk_bjsr_gender USING UNIQUE kode_kel" CLASS NAME "1000-2000" TEMPLATE "./template_gender.html" EXPRESSION ([ljum_bj]>=1000 and [ljum_bj]<=2000) STYLE COLOR 255 255 0 OUTLINECOLOR 0 0 0 WIDTH 2 ANTIALIAS TRUE END#STYLE END #CLASS CLASS NAME "2001-4000" TEMPLATE "./template_gender.html" EXPRESSION ([ljum_bj]>=2001 and [ljum_bj]<=4000) STYLE COLOR 255 255 100 OUTLINECOLOR 0 0 0 WIDTH 2 ANTIALIAS TRUE END#STYLE END #CLASS CLASS NAME "4001-8000" TEMPLATE "./template_gender.html" EXPRESSION ([ljum_bj]>=4001 and [ljum_bj]<=8000) STYLE COLOR 200 200 0 OUTLINECOLOR 0 0 0 WIDTH 2 ANTIALIAS TRUE END#STYLE END #CLASS CLASS NAME "8001-16000" TEMPLATE "./template_gender.html" EXPRESSION ([ljum_bj]>=8001 and [ljum_bj]<=16000) STYLE COLOR 150 150 0 OUTLINECOLOR 0 0 0 WIDTH 2 ANTIALIAS TRUE END#STYLE END #CLASS CLASS NAME " >16000" TEMPLATE "./template_gender.html" EXPRESSION ([ljum_bj]>=16000) STYLE COLOR 100 100 0 OUTLINECOLOR 0 0 0 WIDTH 2 ANTIALIAS TRUE END#STYLE END #CLASS END #LAYER
Thanks a lot and sorry makes confuse :)
-Theresia
To: [hidden email]
Sent: Wed, August 25, 2010 11:26:23 PM
Subject: [mapserver-users] Re: How to appear Graph?
You may like to visit following URL for charting...
http://mapserver.org/output/dynamic_charting.h...
mapserver-users mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/mapserver-users
[hidden email]
View message @ http://osgeo-org.1803224.n2.nabble.com/How-to-appear-Graph-tp5463915p5469290.html
To start a new topic under Mapserver - User, email ml-node+1969211-445975465-96454 at n2.nabble.com
To unsubscribe from Mapserver - User, click here.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-appear-Graph-tp5463915p5469882.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100827/0a9f16ce/attachment.html
