[mapserver-users] Mapserver crashes with large number of layers
Oliver Wesp
oliver.wesp at gmail.com
Wed Dec 8 14:48:51 EST 2010
Hello,
thanks for your help. Like you recommended I tried the request through
the commandline hoping for some kind of new error messages. Instead
the request just did what it should und returned the png without any
error. So it works through commandline and crashes through cgi.
I also made a test on a 32bit machine and it shows the same behaviour.
And indeed we build mapserver by ourself but we can replicate the
problem with the binary from MS4W.
Best regards,
Oliver
2010/12/8 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
> Hello,
> I can give you the steps that I would do in this situation:
> - test this on a different machine
> - test on a 32bit machine
> - test on a Linux machine
> - if you build mapserv yourself, test with a binary/package (MS4W, FGS) and
> see if you can replicate the problem
> - convert your layers to shapefiles and retest (in other words see if
> avoiding using OGR helps at all)
> - get the exact CGI query string that causes problems in your browser and
> then try that same command through the commandline (examples at:
> http://www.mapserver.org/cgi/mapserv.html)...actually I would try that test
> first (because an error might be shown at the commandline, that is not
> displayed through the browser)
> - test with one big mapfile (avoid using includes just to see if that is the
> issue)
> - it might be an issue with tileindex on a layer...so if possible test
> without using a tileindex
> - but really, the best test is to start reducing the number of layers until
> you find the minimum number of layers that still cause the problem..then
> focus your testing on those few layers that are causing troubles (I often do
> this, and yes it takes time)
> Those are my initial thoughts.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 10-12-08 10:58 AM, Oliver Wesp wrote:
>> Dear List,
>> we're kind of stuck with the following problem:
>> First of all we are running Mapserver 5.6.5 in CGI Mode on Windows
>> 2003 Server (64bit). Webserver is Apache 2.2.
>> We have a large Mapfile (seperated into 5 different parts using
>> INCLUDE) with a total of 571 Layers. The layers have different
>> MAXSCALEDENOM values so not all of them are drawn at all scales. The
>> layers are referencing the DATA via TILEINDEX (it's S-57 data read
>> through OGR). Most of the layers cover only a small area, so if I zoom
>> in to the map more and more layers must be taken into account of
>> drawing but only a small number must be drawn. All of the layers are
>> divided into three groups using the GROUP parameter.
>> What happens if I zoom in to the map at some point mapserver crashes
>> (actually it's not crashing it just stucks). If I reduce the total
>> number of layers (by commenting out parts of the mapfile) the map will
>> be drawn again. So my guess is that there is a problem with the number
>> of layers (or styles?, or symbols?, or number of layers per group?)
>> included.
>> I turned on debugging on all of my layers but that didn't helped. If I
>> check the taskmanager mapserver.exe goes to 100% cpu usage and goes
>> back to zero after a few seconds but it's not being terminated. It's
>> still running in the process list. Debug output stops right in the
>> middle of the line. No error message is send to the client or written
>> to any of the logfiles. Actually no response is send to the client at
>> all. If I terminate the process using the task manager "Premature end
>> of script headers: mapserv.exe" is written to the apache error.log and
>> the client shows "Internal Server Error".
>> Right know we have no idea of what to look at. If anybody has any hint
>> what might goes wrong we maybe would be able to look at it and maybe
>> fix it. But right now we're stuck.
> mapserver-users at lists.osgeo.org
