[mapserver-users] long-running postgres queries initiated by mapserver
Carlos Ruiz boolean10001 at yahoo.com
Tue Dec 21 10:06:35 PST 2010
Your welcome, Matt.
Now it is clear why the query is slow.
You must have indices on the columns that you're searching in (and run VACUUM
frecuently to keep them
updated). If you're using LIKE operator, then the indices are not useful if the
columns are not LOCALEd.
Check if you have defined LOCALE to speed up the LIKE matching.
Also, if the data doesn't change at all, you can CLUSTER the table to improve
the query speed.
IC Carlos Ruiz
From: Matt Mendick <matt.mendick at pictometry.com>
To: Carlos Ruiz <boolean10001 at yahoo.com>; "mapserver-users at lists.osgeo.org"
<mapserver-users at lists.osgeo.org>
Sent: Tue, December 21, 2010 10:43:46 AM
Subject: RE: [mapserver-users] long-running postgres queries initiated by
mapserver
Carlos,
Thank you for your response, and indeed the tables do have  indices. The spatial
search is just fine and comes back very quickly, however  the text-based
searches do not come back quickly (propertyIsLike for  example).  I suppose I
wasn't clear enough in my original question.   Mapserver does a case insensitive
"like" query on the postgres server and on  tables that are very large (millions
of rows), this takes too long.  We are  training the customers to search for
things more intelligently, but we cannot  stop them entirely.  We are looking
into a full-text indexing methodology,  but in the meantime, we need to solve
the problem of the long-running  queries.
-Matt
 From: Carlos Ruiz  [mailto:boolean10001 at yahoo.com]
Sent: Tuesday, December 21, 2010  10:23 AM
To: Matt Mendick;  mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users]  long-running postgres queries initiated by
mapserver
Matt,
I  suggest to enhance the PostgreSQL performance at first. Each table with
geometry  must have a GiST spatial
index. When you upload a shape file to PostgreSQL,  the shp2pgsql creates this
index specifying the -I
parameter.
Have  you uploaded your data in this way ?
If the geometry have been modified  with PostGIS, you must recompute statistics
to have the index  updated.
Check if you have a spatial index in your table.
Cheers  from México
IC Carlos Ruiz
 From: mattmendick  <matt.mendick at pictometry.com>
To: mapserver-users at lists.osgeo.org
Sent: Tue, December 21, 2010 8:48:19  AM
Subject: [mapserver-users]  long-running postgres queries initiated by mapserver
Hi  All-
I'm running mapserver 5.6.3 under centos 5.4, using fastcgi. I'm  using
postgres as the data storage container, and mapserver is primarily  serving
WFS requests.  Sometimes, people do WFS queries that take a very  long time
(searching for "virginia" on a nation-wide layer) and eventually  postgres
will return with the result after a long time (hours later), however  the
client has cancelled the WFS request.  Is there any way for  mapserver to
know that the client has cancelled the http request, and it can  therefore
stop the DB query to postgres?  I tried using persistent and  non-persistent
connections with this:
PROCESSING  "CLOSE_CONNECTION=DEFER"
but that didn't change the  behavior.
Thanks a lot!
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/long-running-postgres-queries-initiated-by-mapserver-tp5855539p5855539.html
Sent  from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users  mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
NOTICE: This message is covered by the Electronic Communications Privacy Act,
Title 18, United States Code, Sections 2510-2521. This e-mail and any attached
files are the exclusive property of Pictometry International Corp., are deemed
privileged and confidential, and are intended solely for the use of the
individual(s) or entity to whom this e-mail is addressed. If you are not one of
the named recipient(s) or believe that you have received this message in error,
please delete this e-mail and any attachments and notify the sender immediately.
Any other use, re-creation, dissemination, forwarding or copying of this e-mail
is strictly prohibited and may be unlawful.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101221/e1882738/attachment.htm>
More information about the MapServer-users mailing list
