[mapserver-users] Projection and mapquery
Morten Sickel
Morten.Sickel at nrpa.no
Tue Feb 2 07:20:26 EST 2010
OK, i found a workaround to the original problem:
> I presently have a set up in which I plot some measurements on some
> background maps. Things work fine, but I want to add the possibility
> to query the measurement data set by clicking on a measurement. The
> measurements have coordinates in lat lon and I only manage to query
> those data if I plot the entire map in the same projection.
(the map should be in utm, I would prefer not having to reproject the measurement locations)
I create a new map object with the layer to be queried, set the projection of the new map object to the same as the queried layer and then I do a queryByPoint on the new map object. This works to get find a object. To plot the query map, I get a unique id for the selected point, do a queryByAttributes on the corresponding layer in the drawn map.
Morten Sickel
Norwegian Radiation Protection Authority
=== php code == some parts removed
// I am querying a map layer called "mobile"
// I am using smarty templating for my php script, if you don't know that, just consider the
// $smarty->assign calls as a way to get something printed out.
function pix2geo($mapx,$mapy,$minx,$miny,$maxx,$maxy,$sizex,$sizey)
// calculates geographical coordinates in the map from click coordinates on the image
list($miny,$maxy)=array($maxy,$miny);
// swaps miny and max y since the coordinates acsends upwards in the map, downwards in the picture
$geopoint=array();
foreach( array('x','y') as $dim){
$p=array();
foreach(array('map','min','max','size') as $par){
$name="$par$dim";
$p[$par]=$$name;
$geowidth=$p['max']-$p['min'];
$geopoint[$dim]=$p['map']/$p['size']*$geowidth+$p['min'];
return(array($geopoint['x'],$geopoint['y']));
$map=ms_newMapObj($map_path.'mobilweb.map');
$foundresults=false;
if($_GET['extent']){
list($minx,$miny,$maxx,$maxy)=explode(" ",$_GET['extent']);
$map->setextent($minx,$miny,$maxx,$maxy);
$clickpoint=ms_newpointObj();
$clickpoint->setXY($_GET['MAP_x']*1,$_GET['MAP_y']*1);
if(!isset($_GET['update'])){
if($_GET['action']=='QUERY'){
list($geoX,$geoY)=pix2geo($_GET['MAP_x']*1,$_GET['MAP_y']*1,$minx,$miny,$maxx,$maxy,$map->width,$map->height);
$geopoint=ms_newpointObj();
$geopoint->setXY($geoX,$geoY);
$mapproj=$map->getProjection();
$layerproj=$map->getlayerbyname('mobil')->getProjection();
if($mapproj!=$layerproj){
$oMapproj=ms_newProjectionObj($mapproj);
$oLayerproj=ms_newProjectionObj($layerproj);
$geopoint->project($oMapproj, $oLayerproj);
// projects the point from the projection of the map to the projection of layer
$newmap=$map->clone(); // Might be better to make a new object and then add the querylayer to that object
$newmap->setProjection($layerproj);
$querymap=$newmap;
}else{
$querymap=$map;
$result=@$querymap->queryByPoint($geopoint, MS_SINGLE , -1);
if ( $result==MS_FAILURE ) {$smarty->assign('mapmessage','No data found');}
$layername='mobil';
$layerfield='id';
$oLayer = $querymap->GetLayerByName($layername);
$numResults = $oLayer->getNumResults();
if($numResults){
$foundresults=true;
$oLayer->open();
for ($iRes=0; $iRes < $numResults; $iRes++)
$oRes = $oLayer->getResult($iRes);
$oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
$result=$oShape->values[$layerfield];
$smarty->assign('queryresult',$result);
$smarty->assign('querytime',date("Y.m.d H:i:s",$oShape->values['utctime']));
$oShape->free;
$oLayer->close;
if($querymap!=$map){ // Must transfer the information back to the map that is to be plotted
// NB, the field I'm using is the primary index in the database table, i know it is unique.
$oLayer=$map->GetLayerByName($layername);
$oLayer->queryByAttributes($layerfield,$result,MS_SINGLE);
