[mapserver-users] areas of high res
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Feb 2 17:30:28 EST 2010
Easy solution is to push all the images into same tileindex. Add a new attribute, let's say "draw_order" and give value 1 for 1:500000 images, value 2 for 1:250000 images. Run the tileindex through "sortshp" utility and sort it by draw_order. Now Mapserver will draw both tiffs in overlapping area, but high-resolution will be on top.
Improved way is to remove those tiles which will not be drawn from the tileindex. It goes well with OpenJUMP but there is a little bit work.
- create tileindex of 1:500000 with draw_order field
- create tileindex of 1:250000 with draw_order field
- make union of all polygons in the 1:250000 tileindex
- select polygons from 1:500000 which are covered by the union
- delete selected polygons
- combine what is left from 1:500000 tileindex and 1:250000 tileindex
- sort with "sortshp".
Now there will be less double rendering and 1:250000 areas will be faster.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Wendell Turner
Lähetetty: ti 2.2.2010 23:34
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] areas of high res
The base layer of my map has full coverage of the US at a
scale of 1:500,000. That works fine. I have some areas of
detail that have tif files at a scale of 1:250,000. What do
I put in the mapfile to say 'use high res if available for
this tile, otherwise use the low res one'?
Thanks,
Wendell
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
