[mapserver-users] Re: high quality print from external wms
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Feb 4 07:10:37 EST 2010
Looks like the question is about how to configure Mapbender because it is the one that sends the requests. Unfortunately I cannot help you with it. For sure there is pease of code that defines the printout extents.
You will see the effect of MAXSIZE if you change it to 500 and repeat the request that used to yield a nice map. MAXSIZE is just a throttle that is there for protecting Mapserver against oversized requests. It either prevents the request or let it go through to Mapserver, it does not alter the request in any way.
-Jukka-
Puolesta Basti2025 wrote:
> Hi Jukka,
> At first, I´m using Mapbender, who created the request to my
> mapserver.
> In the mapfile is a connection to another wms.
> -> I have to go this way, because the legend of the external wms is
> really bad
> I know that the external wms accept a size not bigger then 2048.
> And when I change HEIGHT and WIDTH in the URL to 2048. I see
> a very nice
> map.
> But i don't know how to change these settings?
> It seems like my changes in the mapfile (MAXSIZE) has no effect on the
> request.
> regards
> Bastian
> http://n2.nabble.com/high-quality-print-from-external-wms-tp45
> 00369p4513023.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
