[mapserver-users] hyper-threading and performance
Andy Colson
andy at squeakycode.net
Mon Feb 8 16:03:38 EST 2010
Yeah, I've heard the same thing. If your system is cpu bound then I'd
bet the difference between enabled and disabled is minimal (regardless
if the difference is faster or slower). 20% either way is not very much.
If your not cpu bound, I'd bet you see no difference at all.
Of course, these are hugely big guesses. And probably wrong. I dont
have any numbers to share. Sorry.
-Andy
On 2/8/2010 2:48 PM, Mark Volz wrote:
> Andy,
> To be more specific:
> I am using GeoMoose. GeoMoose draws each layer separately so we do benefit
> by having a multi-core processor even if there is only one user. We also are
> using a WMS Service so air photos is for the most part a non issue. If my
> understanding is correct hyper-threading has up to a 20 percent increase in
> speed. However, the performance increase is highly application specific and
> in some cases performance may actually be lower with Hyper-Threading enabled.
> Mark Volz
> GIS Specialist
> Lyon County, MN
> -----Original Message-----
> From: Andy Colson [mailto:andy at squeakycode.net]
> Sent: Monday, February 08, 2010 2:30 PM
> To: Mark Volz
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] hyper-threading and performance
> On 2/8/2010 2:20 PM, Mark Volz wrote:
>> Hello,
>> Does anyone know if the performance of Mapserver is increased if
>> hyper-threading is enabled? If so how much?
>> Mark Volz
>> GIS Specialist
>> Lyon County, MN
> Hey Mark,
> What sort of usage are we talking? Web hosting? Shapefiles and arials?
> I'm not sure if mapserver itself will use mult-threads, but if you
> have multiple requests comming into a website, apache/cgi/mapserver/etc
> will use multi process/threads/etc.
> Its tough to say the performance increase. I'm host several maps on a
> dual-core box, and the cpu's sit around 2 percent. And with lots of
> arial imagery you might hit disk io limit before you hit cpu limit.
> (However, I have had some mrsid files that were really cpu intensive to
> uncompress, they were cpu bound). Are your cpu's even pegged?
> So, I guess, the answer is, it really depends on a lot of different
> variables.
> -Andy
