[mapserver-users] php mapscript loadQuery problem
Moen, Paul T.
pmoen at nd.gov
Tue Feb 9 15:31:15 EST 2010
What would I use for a CLASSITEM when my expression is a Logical “MapServer expressions”?
For example.
EXPRESSION ('[SURFACE]' == 'Paved' AND '[ROADCLASS]' == 'Primary')
Thanks,
Paul
On Feb 9, 2010, at 2:00 PM, Daniel Morissette wrote:
Moen, Paul T. wrote:
> The right items are high lighted now but I get many of the following errors when I dumping the error stack.
> Error in msEvalExpression(): Cannot evaluate expression, no item index defined.
> This only seems to happen when there are many classes in the layer. Are these errors expected?
This would happen if you have classes with string constants (EXPRESSION
"...") or regular expressions (EXPRESSION /.../), but you did not
specify an ITEM in the layer definition (so MapServer has no attribute
value to use in matching the expression).
Daniel
Daniel Morissette
http://www.mapgears.com/
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
