[mapserver-users] Re: Blank image result after the call
http://localhost/mapserver/mapserv.exe?map=ecw.map&mode=map
Kiks
enrico.oemi at gmail.com
Fri Feb 19 10:33:08 EST 2010
Adjusting the MIME types I find the problem and I managed to make a WMS call
to my raster maps, and I make an shp index for my tiles, too!
Thanks a lot.
I still have one other little problem that I can't solve...
In the WMS call, if I put height and width approssimativly major than 550
pixel, the jpeg file seems to be corrupted. The MAXSIZE = 2048 has not
resolved the problem.
Any Ideas?
Kiks
This is my new filemap:
MAP
NAME Ortofoto
# CONFIG "MS_ERRORFILE" "stdout"
# DEBUG 3
CONFIG "ON_MISSING_DATA" "IGNORE"
MAXSIZE 2048
UNITS METERS
EXTENT 1533000 4450600 2668880 4961480
OUTPUTFORMAT
NAME jpeg
DRIVER "GD/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
END
CONFIG "PROJ_LIB" "C:\Programmi\FWTools2.4.6\proj_lib"
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "orto"
TYPE RASTER
STATUS DEFAULT
# TRANSFORM FALSE
# DATA "c:\tematismi\ortofoto\197120.ecw"
TILEINDEX "Ortofoto.shp"
TILEITEM "Location"
END # Layer
END # Map File
View this message in context: http://n2.nabble.com/Blank-image-result-after-the-call-http-localhost-mapserver-mapserv-exe-map-ecw-map-mode-map-tp4596732p4598441.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
