[mapserver-users] Linetype with spikes around a polygon
Bob Basques
bob.b at gritechnologies.com
Sat Feb 20 15:38:03 EST 2010
All,
The only way that might be possible, would be if the colosed polygons
were always drawn in the same direction, clockwise, or
counterclockwise. Otherwise, there is no method for defining right or
left. If the direction of the polygon can be garenteed, then it's a
pretty simple matter to accomplish.
bobb
On 2/19/2010 7:03 AM, Fons Arts wrote:
> Hello list,
> I'm trying to create a linetype, see attached image.
> The spikes has to follow the line. For example, in a rectangle all the
> spikes pointing to the inside.
> Any suggestions would be welcome.
> Mapserver 5.0
> Symbol file
> SYMBOL
> NAME "test"
> TYPE VECTOR
> POINTS
> 0 0
> 1 0
> 0.5 7
> 0 0
> END
> FILLED TRUE
> STYLE
> 1 10 1 10
> END
> END
> Map file
> CLASS
> STYLE
> SYMBOL 'circle'
> OUTLINECOLOR 0 0 0
> SIZE 2
> END
> STYLE
> SYMBOL 'test'
> OUTLINECOLOR 0 0 0
> SIZE 4
> END
> thanks in advance
> Fons
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100220/de940b02/attachment.html
