[mapserver-users] small maps of alaska and hawaii
Julie Knoll
julieknoll at gmail.com
Tue Feb 23 11:07:59 EST 2010
We aren't using open layers, its a completely custom written site. It could
definitely be done, but then there would be a lot of processing going on the
background x 3 and I don't think thats practicle. I also thought about just
physically moving the shapes closer to the US, but theres about 15 layers
that would have to be updated, that still might just be easiest though. I
was hoping there was maybe someway I could use mapservers querymap feature
to do this, but I guess not?
On Tue, Feb 23, 2010 at 10:03 AM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> If you are using something like OpenLayers under the hood, you might just
> create three separate maps, one for each region. You can set the maxextents
> for each map to prevent scrolling outside that area.
> This way each map would have its own controls and its own div and each
> could respond to events in their respective div.
> This is definitely not a mapserver issue, but it is an interesting problem.
> -Steve
> Julie Knoll wrote:
>> Thats what I originally thought about doing, but I don't know how I would
>> go about converting it to the right coordinates when the user clicks on the
>> map. The site I'm working on is http://geofred.stlouisfed.org There's so
>> many other things going on server side to calculate the data and what not
>> that maybe its just not worth the effort.
>> Julie
>> On Mon, Feb 22, 2010 at 1:35 PM, Stephen Woodbridge <
>> woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>> Julie Knoll wrote:
>> Hi, I am working on a site that displays thematic data for the
>> United States, and I would like to include small maps for Alaska
>> and Hawaii in the corners of the main map, rather than having to
>> zoom so far out to see them. Does anyone have any suggestions
>> about the best way of going about doing this? Thanks.
>> This is really a composition problem where you need to compose a
>> single image from multiple separate images. The answer really
>> depends on what media you are using like html, pdf, etc.
>> If you are trying to do this in a web application I would recommend
>> an approach some like:
>> Using PHP/Mapscript, generate you three images and then use PHP GD
>> to compose the three images into a single image and then return that
>> to the browser. You can use a similar approach if you are using PDF
>> depending on the PDF lib you are using.
>> -Steve W
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100223/7ffface4/attachment.html
