[mapserver-users] msplugin_mssql2008.dll plugin seems to work but I
obtain a blank image
Kiks
enrico.oemi at gmail.com
Wed Feb 24 12:18:02 EST 2010
Hi to all,
I have imported in Sql Server 2008 spatial a shp file.
Now, if I access the original shape file via WMS it works fine. This is the
mapfile config relative to the working shp file:
LAYER
NAME "ptcp"
TYPE POLYGON
STATUS DEFAULT
# CONNECTIONTYPE PLUGIN
# PLUGIN "C:\programmi\ms4w\Apache\specialplugins\msplugin_mssql2008.dll"
# CONNECTION "Driver={SQL Server Native Client
10.0};Server=localhost\SQLEXPRESS; Database=GIS;Trusted_Connection=yes;"
# DATA "geom FROM CG_PTCP_C6_AREE_NATURALI"
DATA "E:\Dati cartografici Comuni\Parma PTCP\ptcp
gauss\C6\aree_naturali.shp"
METADATA
"wms_title" "Aree naturali"
"gml_include_items" "all"
END
DUMP TRUE
OPACITY 50
CLASS
STYLE
COLOR 0 0 255
# WIDTH 8
END
LABEL
TYPE truetype
FONT "PerspectiveBlack"
SIZE 11
END
END
If I remark the row DATA "E:\.... \aree_naturali.shp" and I remove the # in
the previous lines to enable the Sql Server 2008 call, executing the WMS
call from browser I obtain a blank image.
I can't understand the different beaviour, because the geometry in Sql
Server is the same, and the connection is accepted correctly.
Any ideas?
Thanks a lot,
Kiks
View this message in context: http://n2.nabble.com/msplugin-mssql2008-dll-plugin-seems-to-work-but-I-obtain-a-blank-image-tp4627179p4627179.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
