[mapserver-users] SQL Server 2008 driver and Reduce() Function
Tamas Szekeres
szekerest at gmail.com
Fri Feb 26 14:29:01 EST 2010
2010/2/26 jwschrader <schraj at gmail.com>
> When using Shp2Img with the reduced geometries, I get a blank layer and the
> debugging message is:
> msMSSQLLayerGetShapeRandom bad shape: #
Jeremy,
This message reports your layer contains null shape(s) which doesn't explain
why you get a blank image. It's more likely due to a projection problem.
Make sure that the map projection corresponds to the extent covering the
desired features to be displayed.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100226/e913d391/attachment.html
