[mapserver-users] Re: SQL Server 2008 driver and Reduce()
Function
Tamas Szekeres
szekerest at gmail.com
Fri Feb 26 17:01:55 EST 2010
Could you provide your sample data and mapfile for further investigation?
Best regards,
Tamas
2010/2/26 jwschrader <schraj at gmail.com>
> Thanks for the quick response.
> I misspoke. The map displays another layer(county boundaries) that is
> pulled from a shape file and just the layer that uses the "reduced"
> geometry
> is blank.
> Also, these reduced geometries are not null. When I run a STIsValid()
> function, they return 1.
> Jeremy
> http://n2.nabble.com/SQL-Server-2008-driver-and-Reduce-Function-tp4641185p4642068.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100226/cd69f626/attachment.html
