[mapserver-users] How to add HDF-EOS data layer in MapServer
Venkat Shesu Reddem
venkat.shesu at gmail.com
Sun Feb 28 23:32:09 EST 2010
Hi Ivan,
this is the gdal_translate which i ran:
gdal_translate -of GTiff -b 1 -a_ullr -180 90 180 -90 -scale 0 1
-a_srs "+proj=latlong +datum=WGS84"
HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/RadiativeCloudFraction
abc.tif
But i don't have clear idea about the usage of PROJECTION parameters,
so how i can use same projection in MapServer LAYER.
with thanks & regards
Venkat
On Mon, Mar 1, 2010 at 4:18 AM, Ivan <ivan.lucena at pmldnet.com> wrote:
> Venkat,
> I am sorry. Your previous e-mail didn't show the SUBDATASET and then I
> assumed that you are dealing with one unsupported flavor of HDF. But if it
> showing, great!
> If you could use gdal_translate to convert to GeoTIFF you can use the same
> identification string on a DATA parameter.
> So, if you ran gdal_translate like that:
> gdal_translate
> HDF5:OMI.he5://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ColumnAmountO3
> output.tif
> Then you should be able to use the same identification on your map file like
> that:
> LAYER
> TYPE RASTER
> DATA
> "HDF5:OMI.he5://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ColumnAmountO3"
> Some time ago I reported a bug in Mapserver that was preventing those
> complex GDAL connection string to work but I believe its fixed now.
> Please, give it a try and let us know if it works or not. And don't forget
> to mention the GDAL and Mapserver version that you are using.
> Regards,
> Ivan
> Venkat Shesu Reddem wrote:
>> Hi Ivan,
>> gdalinfo is showing subdataset list also, the previous mail contains
>> gdalinfo of one of subdataset. I have used gdal_translate to convert
>> the following in GeoTIFF image, however i don't have idea about how to
>> create layer for the given hdf subdataset.
>> the below is the gdalinfo showing subdataset list:
>> Driver: HDF5Image/HDF5 Dataset
>> Files: none associated
>> Size is 1440, 720
>> Coordinate System is:
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.257223563,
>> AUTHORITY["EPSG","7030"]],
>> TOWGS84[0,0,0,0,0,0,0],
>> AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0,
>> AUTHORITY["EPSG","8901"]],
>> UNIT["degree",0.0174532925199433,
>> AUTHORITY["EPSG","9108"]],
>> AUTHORITY["EPSG","4326"]]
>> Metadata:
>> FILE_ATTRIBUTES:OrbitNumber=29703 29704 29705 29706 29707 29708
>> 29709 29710 29711 29712 29713 29714 29715 29716 29717 29718 29719
>> 29720 29721 29722 29723 29724 29725 29726 29727 29728 29729 29730
>> 29731 29732 29733 29734 29735 29736 29737 29738 29739 29740 29741
>> 29742 29743 29744 29745 29746 29747
>> FILE_ATTRIBUTES:OrbitPeriod=5933 5934 5933 5934 5933 5934 5933 5934
>> 5933 5934 5933 5933 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933
>> 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933 5933 5934 5934 5933
>> FILE_ATTRIBUTES:InstrumentName=OMI
>> FILE_ATTRIBUTES:ProcessLevel=3e
>> FILE_ATTRIBUTES:GranuleMonth=2
>> FILE_ATTRIBUTES:GranuleDay=15
>> FILE_ATTRIBUTES:GranuleYear=2010
>> FILE_ATTRIBUTES:GranuleDayOfYear=46
>> FILE_ATTRIBUTES:TAI93At0zOfGranule=5.40346e+008
>> FILE_ATTRIBUTES:PGEVersion="1.0.5.1"
>> FILE_ATTRIBUTES:StartUTC=2010-02-14T12:15:00.000000Z
>> FILE_ATTRIBUTES:EndUTC=2010-02-16T11:45:00.000000Z
>> FILE_ATTRIBUTES:Period=Daily
>> OMI Column Amount O3:GCTPProjectionCode=0
>> OMI Column Amount O3:Projection=Geographic
>> OMI Column Amount O3:GridOrigin=Center
>> OMI Column Amount O3:GridSpacing=(0.25,0.25)
>> OMI Column Amount O3:GridSpacingUnit=deg
>> OMI Column Amount O3:GridSpan=(-180,180,-90,90)
>> OMI Column Amount O3:GridSpanUnit=deg
>> OMI Column Amount O3:NumberOfLongitudesInGrid=1440
>> OMI Column Amount O3:NumberOfLatitudesInGrid=720
>> HDFEOS INFORMATION:HDFEOSVersion=HDFEOS_5.1.11
>> Corner Coordinates:
>> Upper Left ( 0.0, 0.0)
>> Lower Left ( 0.0, 720.0)
>> Upper Right ( 1440.0, 0.0)
>> Lower Right ( 1440.0, 720.0)
>> Center ( 720.0, 360.0)
>> Band 1 Block=1440x1 Type=Float32, ColorInterp=Undefined
>> Metadata:
>> RadiativeCloudFraction:_FillValue=-1267650600228229400000000000000.000000
>> RadiativeCloudFraction:Units=NoUnits
>> RadiativeCloudFraction:Title=Radiative Cloud Fraction = fc*Ic331/Im331
>> RadiativeCloudFraction:UniqueFieldDefinition=TOMS-OMI-Shared
>> RadiativeCloudFraction:ScaleFactor=1
>> RadiativeCloudFraction:Offset=0
>> RadiativeCloudFraction:ValidRange=0.000000 1.000000
>> RadiativeCloudFraction:MissingValue=-1267650600228229400000000000000.000000
>> Driver: HDF5/Hierarchical Data Format Release 5
>> Files: OMI.he5
>> Size is 512, 512
>> Coordinate System is `'
>> Metadata:
>> Subdatasets:
>> SUBDATASET_0_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ColumnAmountO3
>> SUBDATASET_0_DESC=[720x1440]
>> //HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ColumnAmountO3 (32-bit
>> floating-point)
>> SUBDATASET_1_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/RadiativeCloudFraction
>> SUBDATASET_1_DESC=[720x1440]
>> (32-bit floating-point)
>> SUBDATASET_2_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/SolarZenithAngle
>> SUBDATASET_2_DESC=[720x1440]
>> SUBDATASET_3_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ViewingZenithAngle
>> SUBDATASET_3_DESC=[720x1440]
>> Corner Coordinates:
>> Lower Left ( 0.0, 512.0)
>> Upper Right ( 512.0, 0.0)
>> Lower Right ( 512.0, 512.0)
>> Center ( 256.0, 256.0)
>> Venkat
>> On Fri, Feb 26, 2010 at 4:21 PM, Ivan Lucena <ivan.lucena at pmldnet.com>
>> wrote:
>>> Hi Venkat,
>>> If gdalinfo is not showing the subdataset list, like in you case, it
>>> would be impossible to identify a dataset as your DATA parameter.
>>> What version is the GDAL that you are using on command line? Is that the
>>> same that mapserver is using?
>>> Note that there are some flavors of HDF products that are not supported
>>> by all version of GDAL/HDF.
>>> Regards,
>>> Ivan
>>>> -------Original Message-------
>>>> From: Venkat Shesu Reddem <venkat.shesu at gmail.com>
>>>> To: mapserver-users at lists.osgeo.org
>>>> Subject: [mapserver-users] How to add HDF-EOS data layer in MapServer
>>>> Sent: Feb 26 '10 11:02
>>>> Dear All,
>>>> I am trying to add HDF-EOS data layer to MapServer application. Can
>>>> anyone
>>>> help me in defining the syntax of the layer.
>>>> the following is the "gdalinfo" for the given HDF dataset
>>>> Size is 1440, 720
>>>> GEOGCS["WGS 84",
>>>> DATUM["WGS_1984",
>>>> Metadata:
>>>> FILE_ATTRIBUTES:OrbitNumber=29703 29704 29705 29706 29707 29708 29709
>>>> 29710 29711 29712 29713 29714 29715 29716 29717 29718 29719 29720 29721
>>>> 29722 29723 29724 29725 29726 29727 29728 29729 29730 29731 29732 29733
>>>> 29734 29735 29736 29737 29738 29739 29740 29741 29742 29743 29744 29745
>>>> 29746 29747
>>>> 5933
>>>> 5934 5933 5933 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933 5934
>>>> 5933
>>>> 5934 5933 5934 5933 5934 5933 5934 5933 5933 5934 5934 5933 5934 5933
>>>> 5933
>>>> Corner Coordinates:
>>>> Metadata:
>>>> fc*Ic331/Im331
>>>> Venkat
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
