[mapserver-users] mapserver 5.6.0, RFC 52 and driver support
Brent Fraser
bfraser at geoanalytic.com
Mon Jan 4 15:57:22 EST 2010
Steve,
One unexpected requirement of using OUTPUTFORMAT/TEMPLATE (RFC 36) for
the query results is that I still seem to need a LAYER TEMPLATE
definition. It can be set to anything except a zero length string:
LAYER
TEMPLATE 'bogus'
I guess it's required so Mapserver considers the layer queryable?
Thanks!
Brent
> For those following this thread, I used:
> OUTPUTFORMAT
> NAME 'UnassignedWells_select_template'
> DRIVER 'TEMPLATE'
> MIMETYPE 'text/html'
> FORMATOPTION
> 'FILE=database\UnassignedWells_select_template_test.html'
> END
> and added
> [resultset layer="UnAssignedWells"][feature]
> [/feature][/resultset]
> around the per-record text in UnassignedWells_select_template_test.html
> But as suspected, it still didn't solve my performance problem...
> Brent
>> I've got:
>> OUTPUTFORMAT
>> DRIVER 'TEMPLATE'
>> TEMPLATE 'database\UnassignedWells_select_template_test.html'
>> #? FORMATOPTION
>> END
>> in my map file and a command line of:
>> mapserv
>> QUERY_STRING="mode=nquery&qformat=UnassignedWells_select_template&map=select2_Test.map&qlayer=UnAssignedWells&"
>> Am I close?
>> Thanks
>> Brent
>>> Yup. What sort of an example would help?
>>> -----Original Message-----
>>> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
>>> Sent: Tuesday, December 22, 2009 4:18 PM
>>> To: Lime, Steve D (DNR)
>>> Cc: mapserver-users at lists.osgeo.org
>>> Subject: RE: [mapserver-users] mapserver 5.6.0, RFC 52 and driver
>>> support
>>> I'd like to give the new-style approach a try, but the doc seems a
>>> little
>>> thin. You've talking about RFC 36 right?
>>>> The new-style approach opens the template only once. That's not your
>>>> bottleneck though I bet...
>>>> Sent: Tuesday, December 22, 2009 3:34 PM
>>>> support
>>>>> What kind of templating are you using? The old-style stuff or the
>>>>> new-style? How many results you talking?
>>>> Old style. Low 100's of records returned...
>>>>> Sent: Tuesday, December 22, 2009 3:10 PM
>>>>> support
>>>>> The strange thing is the image render is quick (a few seconds), but
>>>>> the
>>>>> nquery+mapshape (rectangle) with the processing of the template is
>>>>> several
>>>>> minutes. And while it opens/reads/closes the template file for each
>>>>> record(!), I suspect the majority of the time is spent requesting the
>>>>> record and dealing with the result.
>>>>> Ok, on goes the hacker suit...
>>>>> Thanks!
>>>>> Brent
>>>>>> Probably a question better answered by OGR maintainers... In theory
>>>>>> working off a single
>>>>>> result set, even if you have to traverse it more than once, would be
>>>>>> far
>>>>>> more efficient
>>>>>> than id-based lookups done now.
>>>>>> Steve
>>>>>> From: mapserver-users-bounces at lists.osgeo.org
>>>>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Brent
>>>>>> Fraser
>>>>>> Sent: Tuesday, December 22, 2009 2:55 PM
>>>>>> support
>>>>>> Do you think there would be any point in making the changes for OGR
>>>>>> (for
>>>>>> my ODBC -> Sql Server connection)? If so, I'll start having a look
>>>>>> at
>>>>>> the
>>>>>> code...
>>>>>> Brent
>>>>>>> The improvements are limited to native drivers only, principally
>>>>>>> Oracle
>>>>>>> Spatial and PostGIS.
>>>>>>> Steve
>>>>>>> Fraser
>>>>>>> Sent: Tuesday, December 22, 2009 2:48 PM
>>>>>>> To: mapserver-users at lists.osgeo.org
>>>>>>> Subject: [mapserver-users] mapserver 5.6.0, RFC 52 and driver
>>>>>>> support
>>>>>>> To all,
>>>>>>> I've got a query performance problem I'm trying to track down. I
>>>>>>> was
>>>>>>> hopeful that 5.6 with RFC 52 implemented might help me, but it
>>>>>>> seems
>>>>>>> to
>>>>>>> have no impact.
>>>>>>> Are the changes for RFC 52 implemented for OGR ODBC connections?
>>>>>>> Thanks!
>>>>>>> Brent Fraser
>>>>>>> _______________________________________________
>>>>>>> mapserver-users mailing list
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
