[mapserver-users] Error configuring WMS app : Projection library
error. Invalid argument...
stela anders
stelaanders at gmail.com
Tue Jan 5 11:18:36 EST 2010
Woww!
Thats it!!!!
Worked now!
Thanksss guysss ! Thanks Daniel!
iuupi!
Stella
2010/1/5 Daniel Walton <dgwalton at gmail.com>
> Stella,
> Try adding a config entry to your mapfile that points to the folder
> containing your epsg configuration file:
> MAP
> CONFIG "PROJ_LIB" "C:/somedir/proj/nad/"
> END
> Dan Walton
> [image: Linkedin] <http://www.linkedin.com/in/danielwalton2010>[image:
> Twitter] <http://twitter.com/danwallie>
> On Tue, Jan 5, 2010 at 9:56 AM, stela anders <stelaanders at gmail.com>wrote:
>> Hello Frank!
>> Thanks for your time ;)
>> I´m working on Windows 7...
>> I made all modifications you suggest me, but got the same error...
>> The URL now is :
>> http://localhost/cgi-bin-last/mapserv.exe?MAP=C:/inetpub/wwwroot/Openlayer/Mapserver/Mapfile/Map.map&LAYERS=Argentina&TRANSPARENT=true&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&SRS=EPSG:4326&BBOX=-62.9142,-17.3676,-57.2892,-11.7426&WIDTH=256&HEIGHT=256
>> The only difference that I noticed is that the error in browser now is in
>> TEXT format...
>> Before the error was write in a Image...
>> I´m completely lost ! :(
>> Any other idea?
>> ps.: Sorry for my bad english
>> Stella
>> 2010/1/5 Frank Warmerdam <warmerdam at pobox.com>
>> stela anders wrote:
>>>> LAYER
>>>> NAME Argentina
>>>> METADATA
>>>> "wms_title" "Argentina" ##required
>>>> END TYPE POLYGON
>>>> STATUS ON
>>>> INCLUDE "Connection.map" DATA "the_geom from
>>>> tbl_argentina USING UNIQUE gid USING SRID=0"
>>>> PROJECTION
>>>> "proj=longlat"
>>>> "ellps=WGS84"
>>>> "datum=WGS84"
>>>> "no_defs"
>>>> END
>>>> CLASS
>>>> COLOR 255 200 255
>>>> END
>>>> END
>>>> END
>>>> When I try to open that with my OpenLayer app, I got images with that
>>>> error :
>>>> Error: msProcessProjection(): /Projection library error/. /Invalid
>>>> argument
>>> Stella,
>>> I am not sure why you are getting this error. I search high and low and
>>> can't
>>> find "Invalid argument" in either MapServer or PROJ.4. Are you working
>>> on
>>> linux or Windows? Were the "/" characters really in this message? It is
>>> hard for me to understand how this could happen.
>>> With regard to your mapfile, I was surprised that you don't have
>>> wms_srs metadata on your layer. It is a shot in the dark, but perhaps
>>> you
>>> could add wms_srs EPSG:4326 metadata on the layer, and reorder the
>>> wms_srs
>>> metadata on the map to put EPSG:4326 first.
>>> Also, you could try changing:
>>> > PROJECTION
>>> > "proj=longlat"
>>> > "ellps=WGS84"
>>> > "datum=WGS84"
>>> > "no_defs"
>>> > END
>>> to:
>>> PROJECTION
>>> "+init=epsg:4326"
>>> END
>>> in both the layer and map. This is slower to expand but it might
>>> make it easier for mapserver to relate to epsg codes.
>>> Best regards,
>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
>>> and watch the world go round - Rush | Geospatial Programmer for Rent
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100105/b0922ae7/attachment.html
