[mapserver-users] How do I have a polygon with an outline with
a width?
Christy Nieman
cnieman at dmsolutions.ca
Wed Jan 6 07:31:41 EST 2010
If you are indeed using MapServer 5.4, you should be able to control the
width of a polygon's outline by specifying an OUTLINECOLOUR and a
WIDTH. I just tested with the 5.4 svn branch and had no trouble.
I'm not sure what you mean by it seems that MapServer cannot read a
symbol file for polygons - I have no problem using it to specify a fill
pattern, but I don't think it can be used to specify an outline style.
Christy
On 01/05/2010 02:59 PM, Andreas Douvalis wrote:
> I test chameleon 2.6 with Mapserver 5.4 and I have problem with
> Polygons Symbols.
> I have already altered my Symbol.sym file to start with "SYMBOLSET"
> and finish with "END".
> In fact I have problem only with polygons and their WIDTH. Lines and
> points works perfect.
> it seems like mapserver can not read Symbol.sym for polygons.
> Here is a part of Layer section in map file:
> LAYER
> NAME "Perifereies"
> GROUP "Διοικητικά Όρια"
> STATUS OFF
> DATA "C:\ms4w\apps\chameleon\samples\dataGreek\Dioikitika\Perifereies"
> TYPE POLYGON
> UNITS METERS
> LABELITEM "NAME"
> METADATA
> wms_name "Περιφέρειες"
> wms_title "Περιφέρειες"
> SPATIALSEARCH "NAME,Έδρα_Περιφ,POP_1991_,POP_2001_,Embad_km2"
> SPATIALSEARCHLIST "NAME,Έδρα_Περιφ,POP_1991_,POP_2001_,Embad_km2"
> END
> TEMPLATE "Perifereies.dbf"
> CLASS
> NAME "Perifereies"
> STYLE
> SYMBOL "circle"
> SIZE 3
> COLOR 12 112 255
> OUTLINECOLOR 0 112 255
> WIDTH 5
> END
> END
> END
> If I dont use '..........SYMBOL "circle".........' and I write :
> STYLE
> COLOR 12 112 255
> WIDTH 5
> END
> everything is ok but then I cannot control outline width.
> Regarding the outputformat here is the part of my map file:
> OUTPUTFORMAT
> NAME 'AGG_Q'
> DRIVER AGG/PNG
> IMAGEMODE RGB
> FORMATOPTION "QUANTIZE_FORCE=ON"
> FORMATOPTION "QUANTIZE_DITHER=OFF"
> FORMATOPTION "QUANTIZE_COLORS=256"
> END
> I HAVE ALREADY CHECK THE ABOVE LINK BUT THERE IS NO CHANGE REGARDING
> THE OUTLINE WIDTH
> http://mapserver.org/faq.html#how-do-i-have-a-polygon-that-has-both-a-fill-and-an-outline-with-a-width
> ANY HELP PLEASE
> Χρησιμοποιείτε Yahoo!
> Βαρεθήκατε τα ενοχλητικά μηνύ ματα (spam); Το Yahoo! Mail διαθέτει την
> καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων
> http://login.yahoo.com/config/mail?.intl=gr
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100106/7d8683eb/attachment.html
