[mapserver-users] Error configuring WMS app : Projection library
error. Invalid argument...
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Jan 6 09:19:53 EST 2010
stela anders wrote:
> Guys, other problem now ;(
> I have 2 layers with same name ... One with LINE and other with
> ANNOTATION ... It works fine in mapscript environment... But now, with
> WMS I got a error when I use both layers with same name:
> msWMSLoadGetMapParams(): /WMS server error/. /Invalid layer/(s) given in
> the /LAYERS/ parameter
> Both layer works separately...
> My 2 layers
> LAYER
> NAME Road
> METADATA
> "wms_title" "Road"
> END
> GROUP "Transport"
> TYPE LINE
> STATUS ON
> INCLUDE "Connection.map"
> DATA ...
> PROJECTION
> "+init=epsg:4326"
> END
> CLASS
> TEMPLATE "dummy"
> NAME "Rod x"
> STYLE
> SYMBOL "road"
> COLOR 0 0 0
> ANTIALIAS TRUE
> END
> END
> END
> LAYER
> NAME Road
> METADATA
> "wms_title" "Road"
> END
> GROUP "Transport"
> TYPE ANNOTATION
> STATUS ON
> DATA ...
> PROJECTION
> "+init=epsg:4326"
> END
> LABELITEM 'rod'
> CLASS
> TEMPLATE "dummy"
> STYLE
> SYMBOL 'roadsymbol'
> END
> LABEL
> TYPE TRUETYPE
> FONT Arial
> SIZE 7
> COLOR 70 70 70
> MINDISTANCE 100
> MINFEATURESIZE 10
> PARTIALS FALSE
> BUFFER 10
> END
> END
> END
> Why?
Hello Stella,
Check your GetCapabilities response of your WMS service - your 2 layers
of the same name were probably renamed by MapServer with unique names
(such as "Road_01" and "Road_02"), so you should request the layers with
those names.
To avoid this you could:
- use different names in your mapfile
- combine your 2 layers into one layer
- since you already have the layers in a group, add a group metadata tag
in the layers, and then use the group name in your WMS LAYERS request
(but first verify names through a GetCapabilities request), such as:
LAYER
NAME "Road"
GROUP "Transport"
METADATA
"wms_title" "Road"
"wms_group_title" "groupname"
END
END
http://localhost/cgi-bin-last/mapserv.exe?MAP=C:/inetpub/wwwroot/Openlayer/Mapserver/Mapfile/Map.map&LAYERS=Transport&...............
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
