[mapserver-users] cofigure problems on Ubuntu 9.10
Alan Boudreault
aboudreault at mapgears.com
Thu Jan 7 09:41:16 EST 2010
I'm mostly sure that the configure script is right, because we use it on
Ubuntu Karmic.
You can see the the configure options used to build the package on karmic
there:
http://svn.debian.org/wsvn/pkg-
grass/packages/mapserver/tags/5.6.0%2Bfinal-1/debian/rules
I don't see "--with-png" in your config options... you should add it if you
want the support.
Otherwise, I suggest to take a look at the "config.log" file to see what's
happen in detail.
Hope this help.
Alan
On January 7, 2010 07:42:29 am Vasile Cristian Stan wrote:
> Thanks Alan
> The packages are installed.
> ii libjpeg62-dev 6b-14build1 Development files for the IJG JPEG
> library
> ii libpng12-dev 1.2.37-1 PNG library - development
> Also, I tried to configure using another script presented here:
> http://n2.nabble.com/Error-running-configure-on-a-Linux-machine-td3278036.h
> tml#a3278036 , and with this script jpeg and png works but the rest of
> packages are not included.
> So, there are no problems with the packages, maybe the configuration script
> is wrong.
> # Vasi
> Alan Boudreault wrote:
> > I would suggest to verify with the dpkg command line if the packages
> > |libpng12-dev and ||libjpeg62-dev |are installed.
> > You can also take a look to these binarie packages:
> > https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable , which
> > contain mapserver 5.6.0.
> > Alan
> > luftadler wrote:
> >> Hi everyone,
> >> I try to install MapServer 5.6.0, for the first time, on my machine
> >> (using
> >> Ubuntu 9.10).
> >> The problem is that my configuration don't find few installed libraries
> >> like: png and jpeg.
> >> My configuration script:
> >> ./configure \
> >> --enable-debug \
> >> --prefix=/usr \
> >> --with-xml2 \
> >> --with-pdf \
> >> --with-gd \
> >> --with-jpeg \
> >> --with-freetype \
> >> --with-agg \
> >> --with-eppl \
> >> --with-proj \
> >> --with-threads \
> >> --with-sde \
> >> --with-geos \
> >> --with-ogr \
> >> --with-gdal \
> >> --with-tiff \
> >> --with-postgis \
> >> --with-wfs \
> >> --with-wcs \
> >> --with-wmsclient \
> >> --with-wfsclient \
> >> --with-sos \
> >> --with-fribidi-config \
> >> --with-php=/usr/include/php5 \
> >> --with-httpd=/usr/sbin/apache2 \
> >> ______________________________________________
> >> MapServer is now configured for
> >> -------------- Compiler Info -------------
> >> C compiler: gcc -g -fPIC -Wall
> >> C++ compiler: g++ -g -fPIC -Wall
> >> Debug: -g
> >> Generic NINT:
> >> -------------- Renderer Settings ---------
> >> OpenGL support:
> >> zlib support: -DUSE_ZLIB
> >> png support:
> >> palette rgba png support:
> >> jpeg support:
> >> iconv support: -DUSE_ICONV
> >> AGG support: -DUSE_AGG
> >> Cairo (SVG,PDF) support:
> >> Ming(flash) support:
> >> PDFLib support: -DUSE_PDF
> >> -------------- Support Libraries ---------
> >> Proj.4 support: -DUSE_PROJ
> >> Libxml2 support: -DUSE_LIBXML2
> >> FriBidi support: -DUSE_FRIBIDI
> >> Curl support: -DUSE_CURL
> >> FastCGI support:
> >> Threading support: -DUSE_THREAD
> >> GEOS support: -DUSE_GEOS -DGEOS_HAS_SIMPLIFY
> >> -------------- Data Format Drivers -------
> >> native tiff support: -DUSE_TIFF
> >> PostGIS support: -DUSE_POSTGIS
> >> EPPL7 support: -DUSE_EPPL
> >> ArcSDE support:
> >> OGR support: -DUSE_OGR
> >> GDAL support: -DUSE_GDAL
> >> Oracle Spatial support:
> >> -------------- OGC Services --------------
> >> WMS Server: -DUSE_WMS_SVR
> >> WMS Client: -DUSE_WMS_LYR
> >> WFS Server: -DUSE_WFS_SVR
> >> WFS Client: -DUSE_WMS_LYR
> >> WCS Server: -DUSE_WCS_SVR
> >> SOS Server: -DUSE_SOS_SVR
> >> -------------- MapScript -----------------
> >> PHP MapScript: yes
> >> #Vasi
Alan Boudreault
Mapgears
http://www.mapgears.com
