[mapserver-users] Truncated msGMLOutput
Yves Moisan
yves.moisan at boreal-is.com
Thu Jan 7 11:12:29 EST 2010
Hi All,
I have a truncated msGMLOutput document for one of my layers and I fail
to understand where the problem is. It looks similar to
http://trac.osgeo.org/mapserver/ticket/779 but for GetFeatureInfo. I'm
running MS 5.2.1 under windows. I tried to run the query on the
commandline and here's what I get :
E:\mydir\ms4w\Apache\cgi-bin>mapserv
"QUERY_STRING=map=../mapfiles/mymapfile.map&QUERY_LA
YERS=stations&LAYERS=stations&REQUEST=GetFeatureInfo&EXCEPTIONS=application%2Fvnd.ogc.se_xml&VERSION
=1.0.0&SRS=EPSG%3A32644&BBOX=373865.273287%2C2090503.076491%
2C374934.203341%2C2090907.506727&X=406&Y
=293&INFO_FORMAT=gml%3B%20charset%3Diso-8859-1&FEATURE_COUNT=1000"
Content-type: text/xml
<?xml version="1.0" encoding="ISO-8859-1"?>
<msGMLOutput
xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<stations_layer>
I guess there's something wrong in my layer definition but I can't see
it so here it is :
LAYER
NAME 'stations'
TYPE POINT
DUMP TRUE
STATUS On
TEMPLATE void
CLASSITEM e_cat_station_type_id
CONNECTION 'user=user password=pwd dbname=mydb host=localhost
port=5433'
CONNECTIONTYPE POSTGIS
DATA '"the_geom_dummy_32644" FROM "e_cat_station" USING UNIQUE
e_cat_station_id USING SRID=32644'
METADATA
'DESCRIPTION' 'Stations'
'LAYER_ENCODING' 'UTF-8'
"wms_title" "Monitoring station"
"wms_srs" "EPSG:32644"
"gml_include_items" "all"
END # Metadata
TRANSPARENCY 100
TOLERANCE 5
CLASS
NAME "Number7"
EXPRESSION "7"
STYLE
SYMBOL 'circle'
OUTLINECOLOR 0 0 0
COLOR 0 255 0
SIZE 18
END
END
CLASS
NAME "All Stations"
STYLE
SYMBOL 'circle'
OUTLINECOLOR 0 0 0
COLOR 255 0 0
SIZE 6
END
END
END # Layer
The layer shows well (except for the CLASSITEM which I have to sort out,
but that's another issue). What am I doing wrong and also how can a
truncated XML be generated like this ?
TIA,
Yves Moisan
