[mapserver-users] Truncated msGMLOutput
Yves Moisan
yves.moisan at boreal-is.com
Thu Jan 7 15:37:14 EST 2010
> My first guess would be that the mapserv process aborts (seg faults?).
> I'd suggest you enable MS_ERRORFILE/DEBUG at both the map and layer
> level and look for any hints in the debug output. Also check your Apache
> error_log for signs of a seg fault (not sure if you'd see anything on
> Windows though).
> Daniel
Hi Daniel,
Yes, I've just set an error file location (as per Julien's offline
suggestion just before yours) and found out the issue was a boolean to
text cast issue. I made a view out of my table getting rid of the
faulty column and everything is ok now.
I wonder why though MS returns a malformed GML output instead of an
error message.
Cheers,
Yves
